Site to Site VPN Connectivity Problem
ChristianPaz
Hi everybody,
I am trying to stablish a VPN site to site between 2 branches without results. The VPN tunnel is not working, i introduce the following commands and this is the result:
bcicperu-asa5510# show crypto ipsec sa
  There are no ipsec sas
bcicperu-asa5510# show crypto isakmp sa
  There are no IKEv1 SAs
  There are no IKEv2 SAs
My inside network is called bcic and the network address is: aa.aa.aa.aa 255.255.255.128
The remote network is called Infomedia and the address is: dd.dd.dd.dd 255.255.255.0
In both sites we use:
Authentication: Pre-share
DH: group 2
Encryption: aes-256
Hash: sha
Sa lifetime: 86400
Here is my running config:
ASA Version 8.4(2)
hostname bcicperu-asa5510
enable password TkoOhnZMamrN7o4G encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif inside
security-level 100
ip address aa.aa.aa.20 255.255.255.128
interface Ethernet0/1
shutdown
nameif future_dmz
security-level 50
no ip address
interface Ethernet0/2
nameif outside
security-level 0
ip address cc.cc.cc.cc 255.255.255.224
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address xx.xx.xx.61 255.255.255.128
management-only
ftp mode passive
object network Infomedia_net
subnet bb.bb.bb.bb 255.255.255.0
object network bcic_net
subnet aa.aa.aa.aa 255.255.255.128
access-list l2l_list extended permit ip object bcic_net object Infomedia_net
access-list inside_access_in extended permit ip any any
access-list management_access_in extended permit ip any any
access-list outside_access_in extended permit ip any any
pager lines 24
logging asdm informational
mtu management 1500
mtu inside 1500
mtu future_dmz 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static bcic_net bcic_net destination static Infomedia_net Infomedia_net
route outside 0.0.0.0 0.0.0.0 cc.cc.cc.33 1
route inside aa.aa.aa.aa 255.255.255.0 aa.aa.aa.1 1
route management zz.zz.zz.128 255.255.255.128 xx.xx.xx.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http xx.xx.xx.xx 255.255.255.128 management
http zz.zz.zz.zz 255.255.255.0 management
http zz.zz.zz.zz 255.255.255.128 management
http aa.aa.aa.aa 255.255.255.128 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set cisco-infomedia esp-aes-256 esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal prop1
protocol esp encryption aes-256
protocol esp integrity sha-1
crypto map l2lmap 1 match address l2l_list
crypto map l2lmap 1 set peer dd.dd.dd.dd
crypto map l2lmap 1 set ikev1 transform-set cisco-infomedia
crypto map l2lmap 1 set ikev2 ipsec-proposal prop1
crypto map l2lmap interface outside
crypto ca server
shutdown
cdp-url http://bcicperu-asa5510.bcicperu.com/+CSCOCA+/asa_ca.crl
issuer-name CN=bcicperu-asa5510.bcicperu.com
smtp from-address admin@bcicperu-asa5510.bcicperu.com
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 2
prf sha
lifetime seconds 86400
crypto ikev1 enable outside
crypto ikev1 policy 1
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
telnet aa.aa.aa.aa 255.255.255.128 management
telnet xx.xx.xx.xx 255.255.255.128 management
telnet zz.zz.zz.zz 255.255.255.0 management
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
tunnel-group-list enable
group-policy DfltGrpPolicy attributes
webvpn
  url-list value Utilitarios
username ???? password 08S9WUsiSMr3RauN encrypted privilege 0
username ???? attributes
vpn-group-policy DfltGrpPolicy
tunnel-group dd.dd.dd.dd type ipsec-l2l
tunnel-group dd.dd.dd.dd ipsec-attributes
ikev1 pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
tunnel-group bcic-portal type remote-access
tunnel-group bcic-portal webvpn-attributes
group-alias bcic enable
group-url https://cc.cc.cc.cc/bcic enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 2
Cryptochecksum:59cf139ecc14afaa3117bee41723a5da
: end
thanks for your help.
Christian Paz
6 Replies 6
ajay chauhan
Level 7
Level 7
Can you also post other side configuration ?
Ajay
Hi Ajay, I  have no access to the other asa. They only sent me the following lines:
crypto map Outside_map 6 match address Outside_6_cryptomap
crypto map Outside_map 6 set peer xx.xx.xx.61
crypto map Outside_map 6 set transform-set ESP-AES-256-SHA access-list Outside_6_cryptomap extended permit ip bb.bb.bb.bb 255.255.255.0 aa.aa.aa.aa 255.255.255.0
6   IKE Peer: xx.xx.xx.61
    Type    : user            Role    : initiator
    Rekey   : no              State   : MM_WAIT_MSG2
It seems that the problem is on my site.
Thank you
Christian
Just enquiring, is there a typo error in the crypto map? aa.aa.aa.aa seems to have different subnet mask.
Yours
remote
is there a need to configure "crypto isakmp enable outside"?
Would you want to try "crypto isakmp nat-traversal"?
Thats correct you should verify remote end configuration.
In genral way  this -MM_WAIT_MSG2 indicates remote end issue.
This message means: MM = Main Mode, WAIT = Waiting, MSG2 = Message 2
Might be remote host message is being dropped before reaching your firewall or maybe there is a firewall in the remote end blocking some TCP or UDP ports required by isakmp used by your site-to-site VPN.
As suggested by Lim ACL mask also does not match both end should use same subnet mask and isakmp should be enable.
Ajay
Thanks for your comments, as Lim suggested there was an error with the mask in the acl.
The new acl is:
In the other hand how can i enable isakmp?
I create an isakmp policy and then apply it to the outside interface, but a new show run doesn't show the changes i've made.
Christian
