Site-To-Site VPN Problem...
sherif3745
Hello Everybody,
Having a huge problem trying to connect 3 different offices via a site to site vpn. Main offices are Cisco 2821 running 12.4 IOS and the remote office is an ASA5505 running 8.4.4.1 and loaded with the Security Plus License. Config is identical on both sites, however, I can't get the VPN connection up and running, show crypto session on the 2821 indicates a Down status.
I'm suspecting it might be a NAT issue, on the 2821 I denied NATing between the 2 Local Subnets (2821 Internal and 5505 Internal) but on the 5505 I can't figure out how to do that, still not really sure if it relates to NAT or not. Debug Crypto IPSec and Debug Crypto ISAKAMP on the 2821 shows nothing but this message "
No peer struct to get peer description".
Here is the Show Run on the ASA5505
enable password ********** encrypted
passwd *********** encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group 1
ip address 129.106.21.xx 255.255.255.255 pppoe setroute
boot system disk0:/asa844-1-k8.bin
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
access-list ACL1 extended permit ip 192.168.1.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list ACL2 extended permit ip 192.168.1.0 255.255.255.0 192.168.10.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-712.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication serial console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set TS1 esp-aes-256 esp-sha-hmac
crypto map abcmap 1 match address ACL1
crypto map abcmap 1 set peer 129.31.43.x
crypto map abcmap 1 set ikev1 transform-set TS1
crypto map abcmap 1 set security-association lifetime seconds 86400
crypto map abcmap 2 match address ACL2
crypto map abcmap 2 set peer 89.37.50.x
crypto map abcmap 2 set ikev1 transform-set TS1
crypto map abcmap 2 set security-association lifetime seconds 86400
crypto map abcmap interface outside
crypto ikev1 enable outside
crypto ikev1 policy 1
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 20
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 20
vpdn group 1 request dialout pppoe
vpdn group 1 localname 7638****
vpdn group 1 ppp authentication pap
vpdn username 7638**** password *****
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 21.x.x.x
ntp server 22.x.x.x
webvpn
anyconnect-essentials
username ****** password $$$$$$ encrypted privilege 15
tunnel-group 129.31.43.x type ipsec-l2l
tunnel-group 129.31.43.x ipsec-attributes
ikev1 pre-shared-key *****
tunnel-group 89.37.50.x type ipsec-l2l
tunnel-group 89.37.50.x ipsec-attributes
prompt hostname context
Any Help would be highly appreciated .
2 Accepted Solutions
Jouni Forss
You seem to be lacking the NAT0 configurations on the ASA side
Insert these configurations
object network LAN
subnet 192.168.1.0 255.255.255.0
object network REMOTE-LAN1
subnet 192.168.0.0 255.255.255.0
object network REMOTE-LAN2
subnet 192.168.10.0 255.255.255.0
nat (inside,outside) source static LAN LAN destination static REMOTE-LAN1 REMOTE-LAN1
nat (inside,outside) source static LAN LAN destination static REMOTE-LAN2 REMOTE-LAN2
This basically tells the ASA that DONT do NAT for the network LAN when the destination is either REMOTE-LAN1 or REMOTE-LAN2.
This should handle the NAT portion. You can ofcourse use different "object network" names if you wish. Above ones are just to illustrate their purpose.
To me it seems that all essential VPN configurations are there. Naturally cant check if they match the other sites.
Please remember to mark the reply as the correct answer if it answered your question.
Ask more if needed
- Jouni
I have personally not used the software you mention on the ASA.
On my test ASAs I regularly use 8.4(5) software level.
I think it might be easier to troubleshoot the L2L VPN on the ASA actually. You can use the ASA itself to initiate the L2L VPN negotiation and monitor where the negotiation fails.
First you should naturally make sure that the Phase 1 goes through and the negotiation reaches Phase2.
There shouldnt be many things related to the VPN parameters that could be wrong.
Naturally you should also check the router side NAT configurations. My above NAT configurations presume that you DONT want to do any NAT between the sites. The sites should be able to communicate with their original IP addresses.
Sadly I am not that familiar with the Router side debugs output and Cisco hardly provides any supporting material to understand even half of them (or I just havent found any documents)
Have you tried to monitor the ASA through ASDM while you are attempting to bring the L2L VPN connection up?
- Jouni
5 Replies 5
Jouni Forss
object network LAN
Ask more if needed
- Jouni
Thanks a lot Jouni, too appreciated! Gonna try it asap and will let you know, will mark your answer either way because your response was lightning fast!
Other sites are having Cisco 2821 with Advanced Enterprise Services 12.4-15T as well as AIM-VPN/EPII-Plus .
Still no luck Jouni, tried it and didn't still work.
Pinging anything from local to local to initiate the kick in for the tunnels doesn't bring anything up and it times out, debugging on the 2821 showed new errors like:
peer does not do paranoid keepalives
Can't decrement IKE Call Admission Control stat outgoing_active since it's already 0.
ignoring retransmission,because phase2 node marked dead -732089843
IPSec policy invalidated proposal with error 256
It's too frustrating for me since I got almost nothing configured on both sides but only the VPN config, I highly doubt that it might be a caveat on the ASA iamge but googled and saw that lots are also complaining from the same issue...
- Jouni
Thanks Jouni, it was kinda weird, disabling the inside interface on the ASA and bringing it up again solved the problem, your efforts was highly appreciated buddy .
