Site to Site VPN Problems With 2801 Router and ASA 5505
joescott4t
I am having some issue setting up a site to site ipsec VPN between a Cisco 2801 router and a Cisco ASA 5505. I was told there was a vpn previously setup with an old hosting provider, but those connections have been servered. Right now I am trying to get the sites to talk to the 2801. Here ere are my current configs, please let me know if you need anything else. Im stumped on this one. Thanks.
IP scheme at SIte A:
IP    172.19.3.x
sub 255.255.255.128
GW 172.19.3.129
Site A Ciscso 2801 Router
Current configuration : 11858 bytes
version 12.4
service timestamps debug datetime localtime
service timestamps log datetime localtime show-timezone
service password-encryption
hostname router-2801
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 4096
aaa new-model
aaa authentication login userauthen group radius local
aaa authorization network groupauthor local
aaa session-id common
clock timezone est -5
clock summer-time zone recurring last Sun Mar 2:00 1 Sun Nov 2:00
dot11 syslog
ip source-route
ip dhcp excluded-address 172.19.3.129 172.19.3.149
ip dhcp excluded-address 172.19.10.1 172.19.10.253
ip dhcp excluded-address 172.19.3.140
ip dhcp ping timeout 900
ip dhcp pool DHCP
   network 172.19.3.128 255.255.255.128
   default-router 172.19.3.129
   domain-name domain.local
   netbios-name-server 172.19.3.7
   option 66 ascii 172.19.3.225
   dns-server 172.19.3.140 208.67.220.220 208.67.222.222
ip dhcp pool VoiceDHCP
   network 172.19.10.0 255.255.255.0
   default-router 172.19.10.1
   dns-server 208.67.220.220 8.8.8.8
   option 66 ascii 172.19.10.2
   lease 2
ip cef
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
no ip domain lookup
ip domain name domain.local
key chain key1
key 1
   key-string 7 06040033484B1B484557
crypto pki trustpoint TP-self-signed-3448656681
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3448bb6681
revocation-check none
rsakeypair TP-self-signed-344bbb56681
crypto pki certificate chain TP-self-signed-3448656681
certificate self-signed 01
  3082024F
            quit
username admin privilege 15 password 7 F55
archive
log config
  hidekeys
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key XXXXX address 209.118.0.1
crypto isakmp key xxxxx address SITE B Public IP
crypto isakmp keepalive 40 5
crypto isakmp nat keepalive 20
crypto isakmp client configuration group IISVPN
key 1nsur3m3
dns 172.19.3.140
wins 172.19.3.140
domain domain.local
pool VPN_Pool
acl 198
crypto isakmp profile IISVPNClient
   description VPN clients profile
   match identity group IISVPN
   client authentication list userauthen
   isakmp authorization list groupauthor
   client configuration address respond
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map Dynamic 5
set transform-set myset
set isakmp-profile IISVPNClient
qos pre-classify
crypto map VPN 10 ipsec-isakmp
set peer 209.118.0.1
set peer SITE B Public IP
match address 101
qos pre-classify
crypto map VPN 65535 ipsec-isakmp dynamic Dynamic
track 123 ip sla 1 reachability
delay down 15 up 10
class-map match-any VoiceTraffic
match protocol rtp audio
match protocol h323
match protocol rtcp
match access-group name VOIP
match protocol sip
class-map match-any RDP
match access-group 199
policy-map QOS
class VoiceTraffic
    bandwidth 512
class RDP
    bandwidth 768
policy-map MainQOS
class class-default
    shape average 1500000
  service-policy QOS
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$FW_INSIDE$
ip address 172.19.3.129 255.255.255.128
ip access-group 100 in
ip inspect SDM_LOW in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/0.10
description $ETH-VoiceVLAN$$
encapsulation dot1Q 10
ip address 172.19.10.1 255.255.255.0
ip nat inside
interface FastEthernet0/1
description "Comcast"
ip address PUB IP 255.255.255.248
ip access-group 102 in
ip inspect SDM_LOW out
ip nat outside
duplex auto
speed auto
crypto map VPN
interface Serial0/1/0
description "Verizon LEC Circuit ID: w0w13908 Site ID: U276420-1"
bandwidth 1536
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
interface Serial0/1/0.1 point-to-point
bandwidth 1536
ip address 152.000.000.18 255.255.255.252
ip verify unicast reverse-path
ip nat outside
frame-relay interface-dlci 500 IETF
crypto map VPN
service-policy output MainQOS
interface Serial0/2/0
description "PAETEC 46.HCGS.788446.CV (Verizon ID) / 46.HCGS.3 (PAETEC ID)"
ip address 123.252.123.102 255.255.255.252
ip nat outside
encapsulation ppp
crypto map VPN
ip local pool VPN_Pool 172.20.3.130 172.20.3.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 50.00.000.110 track 123
ip route 0.0.0.0 0.0.0.0 111.252.237.000 254
ip route 122.112.197.20 255.255.255.255 209.252.237.101
ip route 208.67.220.220 255.255.255.255 50.78.233.110
no ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
top 20
sort-by bytes
ip nat inside source route-map COMCAST interface FastEthernet0/1 overload
ip nat inside source route-map PAETEC interface Serial0/2/0 overload
ip nat inside source route-map VERIZON interface Serial0/1/0.1 overload
ip nat inside source static tcp 172.19.3.140 21 PUB IP 21 extendable
ip access-list extended VOIP
permit ip 172.20.3.0 0.0.0.127 host 172.19.3.190
permit ip host 172.19.3.190 172.20.3.0 0.0.0.127
ip radius source-interface FastEthernet0/0
ip sla 1
icmp-echo 000.67.220.220 source-interface FastEthernet0/1
timeout 10000
frequency 15
ip sla schedule 1 life forever start-time now
access-list 23 permit 172.19.3.0 0.0.0.127
access-list 23 permit 172.19.3.128 0.0.0.127
access-list 23 permit 173.189.251.192 0.0.0.63
access-list 23 permit 107.0.197.0 0.0.0.63
access-list 23 permit 173.163.157.32 0.0.0.15
access-list 23 permit 72.55.33.0 0.0.0.255
access-list 23 permit 172.19.5.0 0.0.0.63
access-list 100 remark "Outgoing Traffic"
access-list 100 deny   ip 67.128.87.156 0.0.0.3 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit tcp host 172.19.3.190 any eq smtp
access-list 100 permit tcp host 172.19.3.137 any eq smtp
access-list 100 permit tcp any host 66.251.35.131 eq smtp
access-list 100 permit tcp any host 173.201.193.101 eq smtp
access-list 100 permit ip any any
access-list 100 permit tcp any any eq ftp
access-list 101 remark "Interesting VPN Traffic"
access-list 101 permit ip 172.19.3.128 0.0.0.127 172.19.3.0 0.0.0.127
access-list 101 permit ip 172.20.3.128 0.0.0.127 172.19.3.0 0.0.0.127
access-list 101 permit ip 172.19.3.128 0.0.0.127 host 172.19.250.10
access-list 101 permit ip 172.19.3.128 0.0.0.127 host 172.19.250.11
access-list 101 permit tcp any any eq ftp
access-list 101 permit tcp any any eq ftp-data
access-list 102 remark "Inbound Access"
access-list 102 permit udp any host 152.179.53.18 eq non500-isakmp
access-list 102 permit udp any host 152.179.53.18 eq isakmp
access-list 102 permit esp any host 152.179.53.18
access-list 102 permit ahp any host 152.179.53.18
access-list 102 permit udp any host 209.000.000.102 eq non500-isakmp
access-list 102 permit udp any host 209.000.000.102 eq isakmp
access-list 102 permit esp any host 209.000.000.102
access-list 102 permit ahp any host 209.000.000.102
access-list 102 permit udp any host PUB IP eq non500-isakmp
access-list 102 permit udp any host PUB IP eq isakmp
access-list 102 permit esp any host PUB IP
access-list 102 permit ahp any host PUB IP
access-list 102 permit ip 72.55.33.0 0.0.0.255 any
access-list 102 permit ip 107.0.197.0 0.0.0.63 any
access-list 102 deny   ip 172.19.3.128 0.0.0.127 any
access-list 102 permit icmp any any echo-reply
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any any unreachable
access-list 102 deny   ip any any log
access-list 102 permit tcp any host 172.19.3.140 eq ftp
access-list 102 permit tcp any host 172.19.3.140 eq ftp-data established
access-list 102 permit udp any host SITE B Public IP  eq non500-isakmp
access-list 102 permit udp any host SITE B Public IP  eq isakmp
access-list 102 permit esp any host SITE B Public IP
access-list 102 permit ahp any host SITE B Public IP
access-list 110 remark "Outbound NAT Rule"
access-list 110 remark "Deny VPN Traffic NAT"
access-list 110 deny   ip 172.19.3.128 0.0.0.127 172.19.3.0 0.0.0.127
access-list 110 deny   ip 172.19.3.128 0.0.0.127 172.19.10.0 0.0.0.255
access-list 110 deny   ip 172.19.10.0 0.0.0.255 172.19.3.128 0.0.0.127
access-list 110 deny   ip 172.20.3.128 0.0.0.127 172.19.3.0 0.0.0.127
access-list 110 deny   ip 172.19.3.128 0.0.0.127 172.20.3.128 0.0.0.127
access-list 110 deny   ip 172.19.3.128 0.0.0.127 host 172.19.250.11
access-list 110 deny   ip 172.19.3.128 0.0.0.127 host 172.19.250.10
access-list 110 permit ip 172.19.3.128 0.0.0.127 any
access-list 110 permit ip 172.19.10.0 0.0.0.255 any
access-list 198 remark "Networks for IISVPN Client"
access-list 198 permit ip 172.19.3.0 0.0.0.127 172.20.3.128 0.0.0.127
access-list 198 permit ip 172.19.3.128 0.0.0.127 172.20.3.128 0.0.0.127
access-list 199 permit tcp any any eq 3389
route-map PAETEC permit 10
match ip address 110
match interface Serial0/2/0
route-map COMCAST permit 10
match interface FastEthernet0/1
route-map VERIZON permit 10
match interface Serial0/1/0.1
snmp-server community 123 RO
radius-server host 172.19.3.7 auth-port 1645 acct-port 1646 key 7 000000000000000
control-plane
line con 0
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
scheduler allocate 20000 1000
ntp server 128.118.25.3
ntp server 217.150.242.8
end
IP scheme at site B:
ip     172.19.5.x
sub  255.255.255.292
gw   172.19.5.65
Cisco ASA 5505 at Site B
ASA Version 8.2(5)
hostname ASA5505
domain-name domain.com
enable password b04DSH2HQqXwS8wi encrypted
passwd b04DSH2HQqXwS8wi encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 172.19.5.65 255.255.255.192
interface Vlan2
nameif outside
security-level 0
ip address SITE B public IP 255.255.255.224
boot system disk0:/asa825-k8.bin
ftp mode passive
clock summer-time zone recurring last Sun Mar 2:00 last Sun Oct 2:00
dns server-group DefaultDNS
domain-name iis-usa.com
same-security-traffic permit intra-interface
object-group network old hosting provider
network-object 72.55.34.64 255.255.255.192
network-object 72.55.33.0 255.255.255.0
network-object 173.189.251.192 255.255.255.192
network-object 173.163.157.32 255.255.255.240
network-object 66.11.1.64 255.255.255.192
network-object 107.0.197.0 255.255.255.192
network-object host 172.19.250.10
network-object host 172.19.250.11
access-list 100 extended permit ip 172.19.5.64 255.255.255.192 object-group old hosting provider
access-list 100 extended permit ip 172.19.5.64 255.255.255.192 172.19.3.128 255.255.255.128
access-list 10 extended deny ip 0.0.0.0 255.0.0.0 any
access-list 10 extended deny ip 127.0.0.0 255.0.0.0 any
access-list 10 extended deny ip 169.254.0.0 255.255.0.0 any
access-list 10 extended deny ip 172.16.0.0 255.255.0.0 any
access-list 10 extended deny ip 224.0.0.0 224.0.0.0 any
access-list 10 extended permit icmp any any echo-reply
access-list 10 extended permit icmp any any time-exceeded
access-list 10 extended permit icmp any any unreachable
access-list 10 extended permit icmp any any traceroute
access-list 10 extended permit icmp any any source-quench
access-list 10 extended permit tcp object-group old hosting provider any eq 3389
access-list 10 extended permit tcp any any eq https
access-list 10 extended permit tcp any any eq www
access-list 110 extended permit ip 172.19.5.64 255.255.255.192 172.19.3.0 255.255.255.128
access-list 110 extended permit ip 172.19.5.64 255.255.255.192 object-group old hosting provider
pager lines 24
logging enable
logging timestamp
logging console emergencies
logging monitor emergencies
logging buffered warnings
logging trap debugging
logging history debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
ip verify reverse-path interface inside
ip verify reverse-path interface outside
ip audit name jab attack action alarm drop reset
ip audit name probe info action alarm drop reset
ip audit interface outside probe
ip audit interface outside jab
ip audit info action alarm drop reset
ip audit attack action alarm drop reset
ip audit signature 2000 disable
ip audit signature 2001 disable
ip audit signature 2004 disable
ip audit signature 2005 disable
icmp unreachable rate-limit 1 burst-size 1
icmp permit 75.150.169.48 255.255.255.240 outside
icmp permit 72.44.134.16 255.255.255.240 outside
icmp permit 72.55.33.0 255.255.255.0 outside
icmp permit any outside
icmp permit 173.163.157.32 255.255.255.240 outside
icmp permit 107.0.197.0 255.255.255.192 outside
icmp permit 66.11.1.64 255.255.255.192 outside
icmp deny any outside
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 100
nat (inside) 1 0.0.0.0 0.0.0.0
access-group 10 in interface outside
route outside 0.0.0.0 0.0.0.0 174.78.151.225 1
timeout xlate 3:00:00
timeout conn 24:00:00 half-closed 0:10:00 udp 0:10:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 24:00:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http 107.0.197.0 255.255.255.192 outside
http 66.11.1.64 255.255.255.192 outside
snmp-server host outside 107.0.197.29 community *****
snmp-server host outside 107.0.197.30 community *****
snmp-server host inside 172.19.250.10 community *****
snmp-server host outside 172.19.250.10 community *****
snmp-server host inside 172.19.250.11 community *****
snmp-server host outside 172.19.250.11 community *****
snmp-server host outside 68.82.122.239 community *****
snmp-server host outside 72.55.33.37 community *****
snmp-server host outside 72.55.33.38 community *****
snmp-server host outside 75.150.169.50 community *****
snmp-server host outside 75.150.169.51 community *****
no snmp-server location
no snmp-server contact
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map VPNMAP 10 match address 110
crypto map VPNMAP 10 set peer 72.00.00.7 old vpn public ip Site B Public IP
crypto map VPNMAP 10 set transform-set ESP-3DES-MD5
crypto map VPNMAP 10 set security-association lifetime seconds 86400
crypto map VPNMAP 10 set security-association lifetime kilobytes 4608000
crypto map VPNMAP interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 20
encryption 3des
hash md5
group 2
lifetime 86400
telnet 172.19.5.64 255.255.255.192 inside
telnet 172.19.3.0 255.255.255.128 outside
telnet timeout 60
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 60
console timeout 0
management-access inside
dhcpd dns 172.19.3.140
dhcpd wins 172.19.3.140
dhcpd ping_timeout 750
dhcpd domain iis-usa.com
dhcpd address 172.19.5.80-172.19.5.111 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection scanning-threat shun except object-group old hosting provider
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 128.118.25.3 source outside
ntp server 217.150.242.8 source outside
tunnel-group 72.00.00.7 type ipsec-l2l
tunnel-group 72.00.00.7 ipsec-attributes
pre-shared-key *****
tunnel-group old vpn public ip type ipsec-l2l
tunnel-group old vpn public ip ipsec-attributes
tunnel-group SITE A Public IP  type ipsec-l2l
tunnel-group SITE A Public IP  ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect pptp
  inspect sip
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:
: end
12 Replies 12
Jiri Zvolanek
Hi Joe.
I think your problem is in crypto access-list at IOS router´s end. Your crypto access-lists dont match each other.
Here you have your crypto access-list on IOS router:
And here is your ACL for VPN from ASA:
At the ASA´s end you have host 172.19.5.64/32 as source for VPN traffic but thist host is not mentioned above in crypto access-list of the IOS router and I dont think "any any" statement would match the ASA´s crypto access-list properly.
Try to insert following line into your ACL 101 at the IOS router before that "any any" statements:
access-list 101 permit ip 172.19.3.128 0.0.0.127 host 172.19.5.64
thank you for your replay how would i add it before that line? Do I need to manually copy the config add the line and then copy it back up?
I believe that this is a valid point. I would ask about one other aspect of the configuration of the IOS router. The crypto map has one instance defined which has two set peer statements. This will result in only one being active at a time (the router will try the first one listed and if it fails then it will try the other one listed). I am not clear whether this is the intended behavior. If the original poster wants only a single tunnel (with redundancy) this approach is fine. But if the intended result is to have two tunnels then there need to be two instances in the crypto map and each instance has a single set peer.
I also note that the crypto map on the IOS router has these destinations
172.19.250.10
172.19.250.11
but I do not see these addresses on the ASA. This mismatch would also cause problems with the VPN tunnel.
Rick
Rick
172.19.250.10
172.19.250.11
Rick
Are you refering to this section:
set peer 209.118.69.7
set peer 174.00.000.248
match address 101
qos pre-classify
the 209 address was a vpn branch to a location that no longer exists. the 174.000.000.248 is the public ip of site B. Should I remove the set peer 209.118.69.7?
Yes I am referring to the section
match address 101
qos pre-classify
If the 209 address no longer exists then I would certainly suggest that you take it out of the config.
I agree with the suggestion that getting a fresh start on the crypto/IPSec VPN on both devices might be a good thing to do.
Rick
Rick
Aso wouldnt i have to allow for access for that whole network?
ive added the line to my router and it now looks like this. I tried a ping to the asa on te other side at 172.29.5.65 but it failed.
I would recommend yout to erase old crypto access-lists on both sides and start from a scratch.
Draw topology on the paper and think about networks on each side which have to communicate with each other.
At the end you should end up with crypto access-lists similar to this (created from your config post, I can see just one network on each side):
IOS router:
access-list 101 permit ip 172.19.3.128 0.0.0.127 172.19.5.64 0.0.0.65
ASA fw:
access-list 110 extended permit ip 172.19.5.64 255.255.255.192 172.19.3.128 255.255.255.128
And I have to agree with Richard, erase that old "set peer" statement from the crypto map on the IOS router.
I have removed the old "set peer" and have added:
IOS router:
ASA fw:
on the router I have also added;
access-list 110 deny  ip 172.19.3.128 0.0.0.127 172.19.5.64 0.0.0.63
Here is my acl :
Still no ping tothe other site.
Watch out for NAT ACL(110) at the IOS router side.
Statement:
is before
So traffic which should be encrypted is translated first and no encryption is done, u have to move it up.
It suppose to look like this:
access-list 110 deny   ip 172.19.3.128 0.0.0.127 172.19.5.64 0.0.0.63                //denying NAT for your VPN traffice between those two subnets
access-list 110 permit ip 172.19.3.128 0.0.0.127 any      //allowing NAT for other traffic not mentioned in previouse statements
access-list 110 permit ip 172.19.10.0 0.0.0.255 any       //allowing NAT for other traffic not mentioned in previouse statements
How do I move a policy up or down?
By this command u will display your ACL with sequence numbers:
router#show ip access-lists 110
Extended IP access list 110
    20 deny ip 172.19.3.128 0.0.0.127 172.19.10.0 0.0.0.255
    30 deny ip 172.19.10.0 0.0.0.255 172.19.3.128 0.0.0.127
    40 deny ip 172.20.3.128 0.0.0.127 172.19.3.0 0.0.0.127
    50 deny ip 172.19.3.128 0.0.0.127 172.20.3.128 0.0.0.127
    60 deny ip 172.19.3.128 0.0.0.127 host 172.19.250.11
    70 deny ip 172.19.3.128 0.0.0.127 host 172.19.250.10
    80 deny ip 172.19.3.128 0.0.0.127 172.19.5.64 0.0.0.63
    90 permit ip 172.19.3.128 0.0.0.127 any
    100 permit ip 172.19.10.0 0.0.0.255 any
router(config)#ip access-list extended 110          //enter extended ACL config
router(config-ext-nacl)#no                //u can modify/delete/create particular statement by sequence number
router(config-ext-nacl)# permit ip ...............
