Site2Site Tunnel issue PSEC(epa_des_crypt): decrypted packet failed SA identity check
I have a slight issue I'm having some problems resolving..
The scenario is as follows;
I have an external provider which connects to me via VPN to a Juniper SSG firewall, that works fine.
I then have an external site, which does NOT reside in my MPLS cloud, so I have to deploy IPSec via Internet to reach it.
That also works fine and I have multiple SA's running on that site with no issues or problems.
The external provider has a small network device deployed on the external site which monitor cooling values in one of our warehouses.
The external site which is connect via IPSEC has a Cisco 1921 and a numerous Cisco 3550 deployed.
The VLAN for the cooling provider is vlan 150 and is setup with 10.150.4.0/24 where .1 is the def gw and .10 is the cooling monitor device.
The external provider's servers are located within 192.168.220.0/24 subnet.
As of right now, we can reach the Cisco 1921 through the whole IPsec tunnel from 192.168.220.182 with all services, ping, telnet whatnot, but we are unable to ping the cooling device from 192.168.220.0/24.
However from the Cisco 1921, we can ping both 192.168.220.0/24 and the locally connected 10.150.4.10
So basicly it seems to be the last bit when the traffic goes through the 1921 and to the switch where it fails and I can't for the life of me figure out why.
This is the 1921 config:
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname bergen-vpn-gw
boot-start-marker
boot system flash flash:c1841-adventerprisek9-mz.124-25d.bin
boot-end-marker
logging buffered 50000
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa session-id common
clock timezone CET 1
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 3:00
no ipv6 cef
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name xxxxx
license udi pid CISCO1921/K9 sn FCZ1508C1P4
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
vtp mode client
redundancy
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key harakiri address 1.2.3.4
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto map VPN 10 ipsec-isakmp
set peer 1.2.3.4
set transform-set 3DES-SHA
match address VPN
interface GigabitEthernet0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0/0.99
description *** Test VLAN To be removed ***
encapsulation dot1Q 99
ip address 10.90.90.1 255.255.255.0
no ip route-cache
interface GigabitEthernet0/0.112
encapsulation dot1Q 112
ip address 192.168.112.1 255.255.255.0
ip helper-address 172.30.1.223
no ip route-cache
interface GigabitEthernet0/0.150
encapsulation dot1Q 150
ip address 10.150.4.1 255.255.255.0
no ip redirects
no ip proxy-arp
no ip route-cache
interface GigabitEthernet0/0.178
encapsulation dot1Q 178
ip address 192.168.178.1 255.255.255.0
no ip redirects
no ip proxy-arp
no ip route-cache
interface GigabitEthernet0/0.999
encapsulation dot1Q 999
no ip route-cache
interface GigabitEthernet0/1
ip address 1.2.3.4 255.255.255.252
no ip redirects
no ip proxy-arp
no ip route-cache
duplex auto
speed auto
crypto map VPN
interface FastEthernet0/0/0
switchport access vlan 99
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 85.200.203.29
ip access-list extended VPN
permit ip 10.90.90.0 0.0.0.255 172.30.1.0 0.0.0.255
permit ip 10.90.90.0 0.0.0.255 172.22.0.0 0.0.255.255
permit ip 10.90.90.0 0.0.0.255 172.18.5.0 0.0.0.255
permit ip 10.90.90.0 0.0.0.255 10.50.0.0 0.0.255.255
permit ip 192.168.112.0 0.0.0.255 172.30.1.0 0.0.0.255
permit ip 192.168.112.0 0.0.0.255 172.22.0.0 0.0.255.255
permit ip 192.168.112.0 0.0.0.255 172.18.5.0 0.0.0.255
permit ip 192.168.112.0 0.0.0.255 10.50.0.0 0.0.255.255
permit ip 192.168.178.0 0.0.0.255 172.30.1.0 0.0.0.255
permit ip 192.168.178.0 0.0.0.255 172.22.0.0 0.0.255.255
permit ip 192.168.178.0 0.0.0.255 172.18.5.0 0.0.0.255
permit ip 192.168.178.0 0.0.0.255 10.50.0.0 0.0.255.255
permit ip 192.168.112.0 0.0.0.255 172.30.240.0 0.0.0.255
permit ip 192.168.178.0 0.0.0.255 172.30.240.0 0.0.0.255
permit ip 192.168.112.0 0.0.0.255 10.70.0.0 0.0.0.255
permit ip 192.168.178.0 0.0.0.255 10.70.0.0 0.0.0.255
permit ip 10.150.4.0 0.0.0.255 192.168.220.0 0.0.0.255 log
ip sla 1
icmp-echo 172.30.1.223 source-interface GigabitEthernet0/0.178
threshold 20
frequency 120
ip sla schedule 1 start-time now
ip sla 2
icmp-echo 10.50.1.200 source-interface GigabitEthernet0/0.178
threshold 20
frequency 120
ip sla schedule 2 start-time now
ip sla 3
icmp-echo 172.18.5.121 source-interface GigabitEthernet0/0.178
threshold 20
frequency 120
ip sla schedule 3 start-time now
ip sla 4
icmp-echo 172.22.0.140 source-interface GigabitEthernet0/0.178
threshold 20
frequency 120
ip sla schedule 4 start-time now
ip sla 5
icmp-echo 172.30.240.40 source-interface GigabitEthernet0/0.178
threshold 20
frequency 120
ip sla schedule 5 start-time now
ip sla 6
icmp-echo 10.70.0.200 source-interface GigabitEthernet0/0.178
threshold 20
frequency 120
ip sla schedule 6 start-time now
cdp source-interface GigabitEthernet0/0.112
snmp-server community bamacomro RO
snmp-server community bamacomrw RW
control-plane
banner motd ^CCC-----------------------------------------------------------------------------
This system is solely for the use of authorised users for official purposes.
You have no expectation of privacy in its use and to ensure that the system
is functioning properly, individuals using this computer system are subject
to having all their activities monitored and recorded by system personell.
Use of this system evidence an express consent to such monitoring and
agreement that if such monitoring reveals evidence of possible abuse or
criminal activity, system personell may provide the result of such
monitoring to appropiate officials.
-----------------------------------------------------------------------------^C
line con 0
exec-timeout 5 0
logging synchronous
line aux 0
line vty 0 4
access-class telnet in
exec-timeout 180 0
logging synchronous
transport input telnet ssh
line vty 5 15
exec-timeout 180 0
password 7 094F471A1A0A
logging synchronous
scheduler allocate 20000 1000
end
5 Replies 5
jawad-mukhtar
Level 4
Level 4
Please add static Routes for VPN ACL Destination IP. Hope it will work.
*** Do Rate Helpful Posts***
Jawad
Hi Jawad,
I'm afraid you'll have to give me an example of what you are taking about there, I didn't quiet get that.
Cheers!
I had that issue 1 year go
"decrypted packet failed SA identity check" means that we have decrypted a traffic that does not match the proxy ID negotiated
Juniper is violating RFC4301. there is nothing we can do against RFC violation
As mentioned in Section 4.4.1, "The Security Policy Database (SPD)",
the SPD (or associated caches) MUST be consulted during the
processing of all traffic that crosses the IPsec protection boundary,
including IPsec management traffic.  If no policy is found in the SPD
that matches a packet (for either inbound or outbound traffic), the
packet MUST be discarded.
I know JNPR can do 2 vpn modes. There is one where we could use a VTI instead of a crypto map on the Cisco side. That was the solution to the problem we had.
Cheers,
Hi and thanks for the suggestion, allthougj I dont think that is the issue here.
Frist of all, as you can see from the config, the 1921 contains multiple SAs and everone of them except the one for 10.150.4.0<->192.168.220.0 works and they are all configured the ssme om both ends
Second, I asume by vti you mean virtuel tunnel interface right? Well, thats how the juniper is configured already, I dont think I've used the cryptomap option on juniper for over 5 years
It must be something else
Hello
The only thing I can say... This counter will increase only if a packet fails the SPD check after decryption [ eg like if the remote device encrypt with the wrong SPI]
Cheers.
