Slow transfer speed over VPN connection
t3ntman0619
Recently I setup an SSL VPN to connect to my parent's home network.  I have some computers there, and want to try to transfer files between my computer and the one at my parent's.  Over the VPN connection, I only get 128kb/s.  On both ends, they are 15Mbps connections, and can support internal copies of 4 megs/s.  I feel like I should get a better speed than that.  I looked around, and people suggested changing the MTU.  I have changed the MTU around, and not noticed any increase in the network speed over the VPN.  Currently the MTU is at 1500.  Below is a copy of my running config.  Any thing I'm overlooking, or is this speed normal?  Sorry, still relatively new to the ASA 5505.
ASA Version 8.2(5)
hostname HardmanASA
enable password #####
passwd ###### encrypted
names
interface Ethernet0/0
switchport access vlan 20
interface Ethernet0/1
switchport access vlan 10
interface Ethernet0/2
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
interface Vlan1
no nameif
no security-level
no ip address
interface Vlan10
nameif inside
security-level 100
ip address 192.168.250.1 255.255.255.0
interface Vlan20
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
access-list nat_0 extended permit ip 192.168.250.0 255.255.255.0 192.168.251.0 255.255.255.0
access-list split_tunnel standard permit 192.168.250.0 255.255.255.0
pager lines 24
mtu inside 1500
mtu outside 1500
ip local pool VPN_Pool 192.168.251.100-192.168.251.101 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 0 access-list nat_0
nat (inside) 10 192.168.250.0 255.255.255.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.250.0 255.255.255.0 inside
http 192.168.251.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.250.0 255.255.255.0 inside
ssh 192.168.251.0 255.255.255.0 inside
ssh timeout 5
ssh version 2
console timeout 0
management-access inside
dhcpd dns 8.8.8.8
dhcpd address 192.168.250.20-192.168.250.50 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
svc image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
svc image disk0:/anyconnect-macosx-i386-2.5.2014-k9.pkg 2
svc image disk0:/anyconnect-linux-2.5.2014-k9.pkg 3
svc enable
tunnel-group-list enable
group-policy DfltGrpPolicy attributes
dns-server value 8.8.8.8
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel
username ###### password ###### encrypted
tunnel-group AnyConnect type remote-access
tunnel-group AnyConnect general-attributes
address-pool VPN_Pool
tunnel-group AnyConnect webvpn-attributes
group-alias AnyConnect enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:74fc2287573841a837e97887840a2d91
: end
6 Replies 6
andduart
In this case should be necessary to enable Dtls, Dtls uses udp, avoids latency and increases bandwitdth. If Udp is blocked the Ssl connection will fallback to regular TLS. You can enable it in Asdm by ckecking it in the interface
Configuration/ remote access / network client access/ ssl connection profile
I just enabled DTLS on both the inside and outside interfaces with no noticeable changes in transfer speed.  Any other suggestions?
andduart
Another option is the use of the compression command, this is usually enabled by default but maybe you can enter it due to is not showed in the running config, the command is compression svc.
Note: The command helps when we have low bandwitdh connections, the command reduces the size if the packets, for broadband connections this can decrease regular performance
Thanks for the suggestion.  After trying the "compression svc" command, I didn't notice any speed increase unfortunately.
leppikallio
This may be the most stupid question ever but have you verified the connection speeds from your parents network behind the ASA5505 to Internet? Also a more up-to-date version of ASA software wouldn't hurt either.
I have verified that each network has 15Mbps via speedtest.net.  Don't you have to have a Cisco premium license to received upgrades?  I just bought this on Amazon, so if I can get free upgrades, I'll definitely go that route.
