SMART CARD: Authentication by certificate and pin code
jds5
we are trying to set up authentication by Smart Card on our VPN access(FPR-2130, Version 9.14(3)9 ) dedicated to our administrators.
The problem comes from the fact that we are not able to require the pin code of the certificate at each connection.
On the first connection, it asks for the pin code, but as long as the workstation is not rebooted or the Cisco Anyconnect service is not restarted; once the pin has been reentered once, it doesn't ask for it again if I disconnect from the VPN and reconnect.
The anyconnect client is in version 4.10.03104.
Hope I was clear,
BR
jds5
Does anyone have experience with this type of solution?
Could he share his experience (configuration,problems encountered, etc )
Does anyone know of this type of setup?
Thanks in advance for your possible answers.
BR,
