{SOLVED} VRF problem. Ping reply works but no data flow.
rmlestraden
Hello there,
I have been breaking my head over the past few day's and I cant get this to work. Perhaps I am making a mistake in the config but I cant see what is wrong with it.
The problem is that I can ping the host's in the other network. And if i do a port scan form subnet 1 to subnet 2 I get open ports. For example if I open the webbrowser and go from 10.0.2.x to 10.0.1.x than I get only port status open. But no page. If I want to telnet from router to router I get no telnet session only status open.
I can ping from router to router but thats it. I cant get active services active :/
Current configuration : 5575 bytes
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
hostname HD1
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
no aaa new-model
memory-size iomem 10
clock timezone GMT 1 0
clock summer-time GMT date
no ip source-route
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip vrf data
rd 65535:1
ip vrf voice
rd 65535:2
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.49
ip dhcp excluded-address 10.0.1.1 10.0.1.49
ip dhcp pool DATA
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 213.144.235.254
option 43 hex 3a02.0005.ff
ip dhcp pool VOICE
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
dns-server 213.144.235.1
option 66 ip 10.0.1.2
no ip bootp server
no ip domain lookup
ip domain name net.lan
ip name-server 213.144.235.1
ip name-server 213.144.235.2
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn
archive
log config
  hidekeys
username admin privilege 15 secret 5 pass
controller VDSL 0
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description Internet_DATA_PVC1
pvc 0/33
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface ATM0.2 point-to-point
description VOICE_PVC2
pvc 0/34
  vbr-rt 200 200
  dialer pool-member 2
interface FastEthernet0
ip vrf forwarding voice
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
description Ethernet poort 3
switchport access vlan 2
no ip address
interface FastEthernet3
description Ethernet poort 4
no ip address
interface Vlan2
description Internet_DATA_VLAN
ip vrf forwarding data
ip access-group 100 in
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Vlan1
description VOICE_VLAN
ip address 10.0.1.1 255.255.255.0
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username user password 7 pass
no cdp enable
interface Dialer2
ip unnumbered Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns view vrf data default
no ip nat service sip udp port 5060
ip nat inside source list 101 interface Dialer1 vrf data overload
ip route vrf data 0.0.0.0 0.0.0.0 Dialer1
ip route vrf voice 0.0.0.0 0.0.0.0 Dialer2
logging trap debugging
access-list 23 permit 10.0.1.0 0.0.0.255
access-list 23 permit 10.0.2.0 0.0.0.255
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 23 permit 83.232.161.0 0.0.0.255
access-list 23 permit 82.94.79.0 0.0.0.255
access-list 23 permit 84.246.25.0 0.0.0.255
access-list 23 permit 172.31.255.0 0.0.0.255
access-list 23 permit 213.144.0.0 0.0.255.255
access-list 23 permit 92.65.31.32 0.0.0.7
access-list 23 permit 192.168.2.0 0.0.0.255
access-list 100 permit ip any any
access-list 100 permit tcp any any
access-list 100 permit udp any any
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
access-list 103 permit ip 10.0.1.0 0.0.0.255 any
access-list 103 permit ip 10.0.2.0 0.0.0.255 any
access-list 103 permit tcp 10.0.2.0 0.0.0.255 any
access-list 103 permit tcp 10.0.1.0 0.0.0.255 any
access-list 103 permit udp 10.0.2.0 0.0.0.255 any
access-list 103 permit udp 10.0.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
no cdp run
control-plane
^C
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
logging synchronous
login local
transport input telnet
end
Config 2
Current configuration : 5772 bytes
version 15.2
no service pad
hostname STR
boot-start-marker
boot-end-marker
no aaa new-model
clock summer-time GMT date Mar 30 2002 1:00 Oct 26 2035 1:59
no ip source-route
ip vrf data
rd 65535:1
route-target export 65535:1
route-target import 65535:1
ip vrf voice
rd 65535:2
route-target export 65535:2
route-target import 65535:2
ip dhcp excluded-address 192.168.2.1 192.168.2.49
ip dhcp excluded-address 10.0.2.1 10.0.2.49
ip dhcp pool DATA
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip dhcp pool VOICE
network 10.0.2.0 255.255.255.0
default-router 10.0.2.1
no ip bootp server
no ip domain lookup
ip cef
no ipv6 cef
archive
log config
  hidekeys
username user privilege 15 secret 5 pass
controller VDSL 0
ip ssh time-out 60
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
description internet_DATA_PVC1
pvc 0/33
pvc 0/34
  vbr-rt 200 200
no ip address
no ip address
no ip address
no ip address
interface Vlan2
description internet_DATA_VLAN
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface Vlan1
ip address 10.0.2.1 255.255.255.0
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
interface Dialer2
ip unnumbered Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
no ip http server
no cdp run
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
logging synchronous
login local
end
Marcin Latosiewicz
Ronald,
What you're describing is most likely a problem with MTU (if ping works and TCP connect port scan returns opens ports) or some very odd problem with forwarding.
BTW - this section of forums if for crypto VPNs not MPLS and such ;-)
M.
Thanks for your quik reply Marcin.
Oops wrong section of the forum. Sorry for that. Perhaps that one of the mods can move this post than
Hmmmm... MTU size could indeed be an issue. But than again. The voice VRF is running over an IPVPN that is provided by the provider. I have been in contact with the provider a few times now and all they say is that there IPVPN is correct. They also took time to look at the configs for both routers and they also say that its correct. Oke. But where could this issue be hidden.
I will get back on this asap.
Thanks again.
rmlestraden
This post may be locked since it is in the wrong section of the forum.
I have started a new one @
https://supportforums.cisco.com/thread/2167844
The problem has been resolved. It was the line provider that made a mistake bij giving the wrong line speed at the second pvc.
After they made the correct changes the connection was made between the 2 routers over the IPVPN
Router config Check
Router firmware Check
First pvc Check
Second pvc but now check
Ipvpn and data flow check
Connection has ben made check
