SSH Issue - urgent Help
patel.nishit
We have configured all the devices to be accessesd via SSH only, but today we can't SSH on any off our devices, all the devices andnetwork connections are fine.
Any idea why this could be.
7 Replies 7
darkbeatzz
can you http to them or is that not allowed? you would need to supply some debug info
nico.bakker
Did you add a domain name and generated an rsa key after that?
Some hints:
- Your hostname should not be the default name "Router"
- First add a domain-name (needed to generate the key)
my-router(config)#ip domain name mydomain
- Then generate a crypto key. I used 1024 bits in this example
my-router(config)#crypto key generate rsa
The name for the keys will be: my-router.mydomain
Choose the size of the key modulus in the range of 360 to 2048 for your
General Purpose Keys. Choosing a key modulus greater than 512 may take
a few minutes.
How many bits in the modulus [512]: 1024
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
#############: %SSH-5-ENABLED: SSH 1.99 has been enabled
my-router(config)#
Patrick Laidlaw
Level 4
Level 4
Did someone push an access-class list to all of your vty ports?
Were you ever able to ssh to these devices?
Did someone change your AAA login method?
Did you use AAA radius or tacacs if so did something happen to it? My money is on this one.
There is no ACL configured on the devices and only local AAA is configured to authenticate local password for SSH.
as I said you need to provide debug info
Did you verify that the username and password are still on the device?
A "debug aaa authentication" and "debug ip ssh" would be really useful.
If you want answers provide those and I'm sure the group would be able to help you much easier.
andrels
have you added this statement under the vty lines ?
transport input ssh ?
