SSL Webvpn and Flash Application issue!!
aotegaoteg
could any expert advice.. we have just setup
cisco clientless webvpn.. and all internal web services
are functionaltiy and working.. but our
external users are finding it diffcult  to stream adobe Flash contents
Eg. youtube or bbc contents.. during the SSL Webvpn session..
could any one advice what is the causes or is this a know bug
and what can we do to allow users to stream adobe Flash contents..
may be we should setup another methord of ssl vpn either full tunnel mode or thin client
thanks
lchance
if you enable your Bookmark to use Smart-Tunnel then it should work.
however, if you try to use the same on an Apple iPad (Safari) then neither FLASH and SILVERLIGHT will work with Webvpn.
