Strange site to site encryption issue with ASA
burleyman
Level 8
Level 8
I am having a strange issue with encryption for a site to site VPN.
The ASA is running Cisco Adaptive Security Appliance Software Version 8.2(5)
Here is my config. The tunnel is up and passes traffic.
object-group network FAR_NETWORKS
  network-object 172.31.174.0 255.255.255.0
  network-object 172.31.175.0 255.255.255.0
  network-object 172.31.176.0 255.255.255.0
  network-object 172.31.177.0 255.255.255.0
  network-object 172.31.178.0 255.255.255.0
access-list FAR-CRYPTOMAP-17 extended permit ip object-group FAR_NETWORKS 172.31.255.128 255.255.255.128
access-list FAR_STATIC_NAT_11 extended permit ip 10.30.1.0 255.255.255.0 172.31.255.128 255.255.255.128
access-list FAR_STATIC_NAT_12 extended permit ip 10.30.16.0 255.255.255.0 172.31.255.128 255.255.255.128
access-list FAR_STATIC_NAT_13 extended permit ip 10.30.3.0 255.255.255.0 172.31.255.128 255.255.255.128
access-list FAR_STATIC_NAT_14 extended permit ip 10.30.12.0 255.255.255.0 172.31.255.128 255.255.255.128
access-list FAR_STATIC_NAT_15 extended permit ip 10.30.7.0 255.255.255.0 172.31.255.128 255.255.255.128
global (outside) 11 172.31.174.1-172.31.174.254 netmask 255.255.255.0
global (outside) 12 172.31.175.1-172.31.175.254 netmask 255.255.255.0
global (outside) 13 172.31.178.1-172.31.178.254 netmask 255.255.255.0
global (outside) 14 172.31.176.1-172.31.176.254 netmask 255.255.255.0
global (outside) 15 172.31.177.1-172.31.177.254 netmask 255.255.255.0
static (inside,outside) 172.31.174.0  access-list FAR_STATIC_NAT_11
static (inside,outside) 172.31.175.0  access-list FAR_STATIC_NAT_12
static (inside,outside) 172.31.178.0  access-list FAR_STATIC_NAT_13
static (inside,outside) 172.31.176.0  access-list FAR_STATIC_NAT_14
static (inside,outside) 172.31.177.0  access-list FAR_STATIC_NAT_15
crypto map MAP-VPN 72 match address FAR-CRYPTOMAP-17
crypto map MAP-VPN 72 set peer 2.2.2.3
crypto map MAP-VPN 72 set transform-set ESP-3DES-SHA
crypto map MAP-VPN 72 set reverse-route
crypto map MAP-VPN interface outside
tunnel-group 2.2.2.3 type ipsec-l2l
tunnel-group 2.2.2.3 ipsec-attributes
 pre-shared-key KEY-Here
Now when I run show ipsec sa peer 2.2.2.3 I see the 172.31.174.0, 172.31.175.0 and they are encap and decap OK along with encrypt and decrypt as well. The I see 172.31.178.0 and it does not show the ACL, and I only see decaps and decrypt but no encaps or encrypt. And I do not see the others at all 172.31.176.0 and 172.31.177.0.
What is causing this issue?
The odd part is if I take these out of the config...
It works and I see all the IP ranges.
Mike
7 Replies 7
rizwanr74
Level 7
Level 7
Hi Mike,
You are using static-policy-nat and dynamic-policy-nat same time to achieve the same result, which I wouldn't do.
Well, if you could see, on which instance of crytop-map is being terminated your tunnel.
show crypto ipsec sa peer 2.2.2.3
Crypto map tag: userdefinedname, seq num: xxxx,
ASA# show ipsec sa peer 2.2.2.3
peer address: 2.2.2.3
    Crypto map tag: MAP-VPN, seq num: 72, local addr: 6.6.6.2
      access-list VOXENT-CRYPTOMAP-17 extended permit ip 172.31.174.0 255.255.255.0 172.31.255.128 255.255.255.128
      local ident (addr/mask/prot/port): (172.31.174.0/255.255.255.0/0/0)
      remote ident (addr/mask/prot/port): (172.31.255.128/255.255.255.128/0/0)
      current_peer: 2.2.2.3
      #pkts encaps: 6836, #pkts encrypt: 6836, #pkts digest: 6836
      #pkts decaps: 6836, #pkts decrypt: 6836, #pkts verify: 6836
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 6836, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 6.6.6.2, remote crypto endpt.: 2.2.2.3
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: 8CDA73C1
      current inbound spi : 7A27569C
    inbound esp sas:
      spi: 0x7A27569C (2049398428)
         transform: esp-3des esp-sha-hmac no compression
         in use settings ={L2L, Tunnel, }
         slot: 0, conn_id: 60235776, crypto-map: MAP-VPN
         sa timing: remaining key lifetime (kB/sec): (3914792/621)
         IV size: 8 bytes
         replay detection support: Y
         Anti replay bitmap:
          0xFFFFFFFF 0xFFFFFFFF
    outbound esp sas:
      spi: 0x8CDA73C1 (2363126721)
         sa timing: remaining key lifetime (kB/sec): (3914792/620)
         IV size: 8 bytes
         Anti replay bitmap:
          0x00000000 0x00000001
      access-list VOXENT-CRYPTOMAP-17 extended permit ip 172.31.175.0 255.255.255.0 172.31.255.128 255.255.255.128
      local ident (addr/mask/prot/port): (172.31.175.0/255.255.255.0/0/0)
      #pkts encaps: 12896, #pkts encrypt: 12896, #pkts digest: 12896
      #pkts decaps: 12896, #pkts decrypt: 12896, #pkts verify: 12896
      #pkts not compressed: 12896, #pkts comp failed: 0, #pkts decomp failed: 0
      current outbound spi: 2E98BB05
      current inbound spi : 42F157C5
    inbound esp sas:
      spi: 0x42F157C5 (1123112901)
         sa timing: remaining key lifetime (kB/sec): (3914617/615)
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
      spi: 0x2E98BB05 (781761285)
         IV size: 8 bytes
         Anti replay bitmap:
    Crypto map tag: MAP-DYN, seq num: 20, local addr: 6.6.6.2
      local ident (addr/mask/prot/port): (172.31.178.0/255.255.255.0/0/0)
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 858, #pkts decrypt: 858, #pkts verify: 858
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      current outbound spi: 0C6A6AB8
      current inbound spi : 9B265EB9
    inbound esp sas:
      spi: 0x9B265EB9 (2602983097)
         slot: 0, conn_id: 60235776, crypto-map: MAP-DYN
         sa timing: remaining key lifetime (kB/sec): (3914936/675)
         IV size: 8 bytes
         Anti replay bitmap:
    outbound esp sas:
      spi: 0x0C6A6AB8 (208300728)
         sa timing: remaining key lifetime (kB/sec): (3915000/675)
         IV size: 8 bytes
         Anti replay bitmap:
So I would remove this...
And keep this...
Hi Mike,
So, it is being terminated on the correct crypto instance 72.
The reason you don't see other other ACL entries on the IPSec SA, is because, that particular flow of data flow was not initiated by users who are behind those private-ip ranges.
thanks
I have continuous pings from all the sites.
Let's start from scratch and I will let you know what I need to accomplish.
I have a main site with other sites that connect to the main site through a private MPLS.
All traffic from the remote sites and the main site will be going across this one tunnel and must be NATed as follows.
Remember the ASA is running 8.2.5 software.
The main site subnet is 172.30.1.0/24
Site A subnet is 172.30.16.0/24
Site B subnet is 172.30.3.0/24
These subnets need to be NATed to the following so they look like they are originating from these subnets
172.30.1.0/24 NAT to 172.31.174.0/24
172.30.16.0/24 NAT to 172.31.175.0/24
172.30.3.0/24 NAT to 172.31.178.0/4
So this will happen.....
172.30.1.111 will NAT to and look like on the other side as 172.31.174.111
so the last octet is preserved.
this traffic only needs to be NATed if the destination subnet is 172.31.255.128/25
How would you configure this.
Local outside IP address is 1.1.1.1
Local inside IP address is 172.30.1.254
The peer IP address is 2.2.2.2
Mike
First make sure your ASA has the route to subnets coming from MPLS cloud.
Your static-policy-nat is fine, unless remote-tunnel subnet overlap with another remote-tunnel of yours and if that is not the case.
You may try this.  I normally use a dynamic-nat as shown below, when traffic is only initiate from my side not from remote-tunnel side.
global (outside) 11 172.31.174.1 netmask 255.255.255.255
nat (inside) 11 access-list FAR_STATIC_NAT_11
global (outside) 12 172.31.175.1 netmask 255.255.255.255
nat (inside) 12 access-list FAR_STATIC_NAT_12
global (outside) 13 172.31.178.1 netmask 255.255.255.255
nat (inside) 13 access-list FAR_STATIC_NAT_13
global (outside) 14 172.31.176.1 netmask 255.255.255.255
nat (inside) 14 access-list FAR_STATIC_NAT_14
global (outside) 15 172.31.177.1 netmask 255.255.255.255
nat (inside) 15 access-list FAR_STATIC_NAT_15
Let me know.
thanks
That will translate ip address lets say in the subnet 172.30.7.0/24 to just one IP address 172.31.177.1 that is not what I need...
172.30.7.101 should NAT to 172.31.177.101
172.30.7.23 should NAT to 172.31.177.23
172.30.7.12 should NAT to 172.31.177.12
and so on for all the Subnets
