Stuck on a VPN problem - can anyone help
Gooner
ISAKMP Header
  Initiator COOKIE: 0b e0 e3 08 39 eb 3d 89
  Responder COOKIE: 00 00 00 00 00 00 00 00
  Next Payload: Security Association
  Version: 1.0
  Exchange Type: Identity Protection (Main Mode)
  Flags: (none)
  MessageID: 00000000
  Length: 188
  Payload Security Association
    Next Payload: Vendor ID
    Reserved: 00
    Payload Length: 136
    DOI: IPsec
    Situation:(SIT_IDENTITY_ONLY)
    Payload Proposal
      Next Payload: None
      Reserved: 00
      Payload Length: 124
      Proposal #: 1
      Protocol-Id: PROTO_ISAKMP
      SPI Size: 0
      # of transforms: 3
      Payload Transform
        Next Payload: Transform
        Reserved: 00
        Payload Length: 36
        Transform #: 1
        Transform-Id: KEY_IKE
        Reserved2: 0000
        Group Description: Group 2
        Encryption Algorithm: 3DES-CBC
        Hash Algorithm: SHA1
        Authentication Method: Preshared key
        Life Type: seconds
        Life Duration (Hex): 00 01 51 80
      Payload Transform
        Reserved: 00
        Payload Length: 40
        Transform #: 2
        Reserved2: 0000
        Encryption Algorithm: AES-CBC
        Key Length: 256
        Life Type: seconds
      Payload Transform
        Next Payload: None
        Reserved: 00
        Payload Length: 40
        Transform #: 3
        Reserved2: 0000
        Group Description: Group 5
        Key Length: 256
        Life Type: seconds
  Payload Vendor ID
    Next Payload: None
    Reserved: 00
    Payload Length: 24
    Data (In Hex):
      40 48 b7 d5 6e bc e8 85 25 e7 de 7f 00 d6 c2 d3
      c0 00 00 00
Feb 21 16:17:27 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:27 [IKEv1]: IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be pr
ocessed when P1 SA is complete.
Feb 21 16:17:29 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:29 [IKEv1]: IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be pr
Feb 21 16:17:30 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:30 [IKEv1]: IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be pr
Feb 21 16:17:31 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:31 [IKEv1]: IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be pr
Feb 21 16:17:32 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:32 [IKEv1]: IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be pr
Feb 21 16:17:34 [IKEv1]: IP = 38.98.146.1, IKE_DECODE RESENDING Message (msgid=0
) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 188
ISAKMP Header
  Version: 1.0
  Flags: (none)
  MessageID: 00000000
  Length: 188
    Reserved: 00
    Payload Length: 136
    DOI: IPsec
    Payload Proposal
      Next Payload: None
      Reserved: 00
      Payload Length: 124
      Proposal #: 1
      SPI Size: 0
      # of transforms: 3
      Payload Transform
        Reserved: 00
        Payload Length: 36
        Transform #: 1
        Reserved2: 0000
        Life Type: seconds
      Payload Transform
        Reserved: 00
        Payload Length: 40
        Transform #: 2
        Reserved2: 0000
        Key Length: 256
        Life Type: seconds
      Payload Transform
        Next Payload: None
        Reserved: 00
        Payload Length: 40
        Transform #: 3
        Reserved2: 0000
        Key Length: 256
        Life Type: seconds
  Payload Vendor ID
    Next Payload: None
    Reserved: 00
    Payload Length: 24
    Data (In Hex):
      c0 00 00 00
Feb 21 16:17:37 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:37 [IKEv1]: IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be pr
Feb 21 16:17:41 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:41 [IKEv1]: IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be pr
Feb 21 16:17:42 [IKEv1]: IP = 38.98.146.1, IKE_DECODE RESENDING Message (msgid=0
ISAKMP Header
  Version: 1.0
  Flags: (none)
  MessageID: 00000000
  Length: 188
    Reserved: 00
    Payload Length: 136
    DOI: IPsec
    Payload Proposal
      Next Payload: None
      Reserved: 00
      Payload Length: 124
      Proposal #: 1
      SPI Size: 0
      # of transforms: 3
      Payload Transform
        Reserved: 00
        Payload Length: 36
        Transform #: 1
        Reserved2: 0000
        Life Type: seconds
      Payload Transform
        Reserved: 00
        Payload Length: 40
        Transform #: 2
        Reserved2: 0000
        Key Length: 256
        Life Type: seconds
      Payload Transform
        Next Payload: None
        Reserved: 00
        Payload Length: 40
        Transform #: 3
        Reserved2: 0000
        Key Length: 256
        Life Type: seconds
  Payload Vendor ID
    Next Payload: None
    Reserved: 00
    Payload Length: 24
    Data (In Hex):
      c0 00 00 00
Feb 21 16:17:45 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:45 [IKEv1]: IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be pr
Feb 21 16:17:47 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:47 [IKEv1]: IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be pr
Feb 21 16:17:50 [IKEv1 DEBUG]: IP = 38.98.146.1, IKE MM Initiator FSM error hist
ory (struct &0x37ceaf8)  <state>, <event>:  MM_DONE, EV_ERROR-->MM_WAIT_MSG2, EV
_RETRY-->MM_WAIT_MSG2, EV_TIMEOUT-->MM_WAIT_MSG2, NullEvent-->MM_SND_MSG1, EV_SN
D_MSG-->MM_SND_MSG1, EV_START_TMR-->MM_SND_MSG1, EV_RESEND_MSG-->MM_WAIT_MSG2, E
V_RETRY
Feb 21 16:17:50 [IKEv1 DEBUG]: IP = 38.98.146.1, IKE SA MM:08e3e00b terminating:
  flags 0x01000022, refcnt 0, tuncnt 0
Feb 21 16:17:50 [IKEv1 DEBUG]: IP = 38.98.146.1, sending delete/delete with reas
on message
Feb 21 16:17:50 [IKEv1]: IP = 38.98.146.1, Removing peer from peer table failed,
no match!
Feb 21 16:17:50 [IKEv1]: IP = 38.98.146.1, Error: Unable to remove PeerTblEntry
Feb 21 16:17:51 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:17:51 [IKEv1]: IP = 38.98.146.1, IKE Initiator: New Phase 1, Intf insi
de, IKE Peer 38.98.146.1  local Proxy Address 10.70.50.0, remote Proxy Address 1
0.10.100.0,  Crypto map (S2S-VPN)
Feb 21 16:17:51 [IKEv1 DEBUG]: IP = 38.98.146.1, constructing ISAKMP SA payload
Feb 21 16:17:51 [IKEv1 DEBUG]: IP = 38.98.146.1, constructing Fragmentation VID
+ extended capabilities payload
Feb 21 16:17:51 [IKEv1]: IP = 38.98.146.1, IKE_DECODE SENDING Message (msgid=0)
SENDING PACKET to 38.98.146.1
ISAKMP Header
  Initiator COOKIE: 96 21 c7 41 66 de df 5c
  Version: 1.0
  Flags: (none)
  MessageID: 00000000
  Length: 188
    Reserved: 00
    Payload Length: 136
    DOI: IPsec
    Payload Proposal
      Next Payload: None
      Reserved: 00
      Payload Length: 124
      Proposal #: 1
      SPI Size: 0
      # of transforms: 3
      Payload Transform
        Reserved: 00
        Payload Length: 36
        Transform #: 1
        Reserved2: 0000
        Life Type: seconds
      Payload Transform
        Reserved: 00
        Payload Length: 40
        Transform #: 2
        Reserved2: 0000
        Key Length: 256
        Life Type: seconds
      Payload Transform
        Next Payload: None
        Reserved: 00
        Payload Length: 40
        Transform #: 3
        Reserved2: 0000
        Key Length: 256
        Life Type: seconds
  Payload Vendor ID
    Next Payload: None
    Reserved: 00
    Payload Length: 24
    Data (In Hex):
      c0 00 00 00
uall
ERROR: % Invalid input detected at '^' marker.
ASA5505# Feb 21 16:17:59 [IKEv1]: IP = 38.98.146.1, IKE_DECODE RESENDING Message
(msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length :
188
ISAKMP Header
  Version: 1.0
  Flags: (none)
  MessageID: 00000000
  Length: 188
    Reserved: 00
    Payload Length: 136
    DOI: IPsec
    Payload Proposal
      Next Payload: None
      Reserved: 00
      Payload Length: 124
      Proposal #: 1
      SPI Size: 0
      # of transforms: 3
      Payload Transform
        Reserved: 00
        Payload Length: 36
        Transform #: 1
        Reserved2: 0000
        Life Type: seconds
      Payload Transform
        Next Payload: Transformu
        Reserved: 00
        Payload Length: 40
        Transform #: 2
        Reserved2: 0000
a        Group Description: Group 2
        Key Length: 256
        Life Type: seconds
      Payload Transform
        Next Payload: None
        Reserved: 00
        Payload Length: 40
        Transform #: 3
        Reserved2: 0000
        Key Length: 256
        Life Type: seconds
  Payload Vendor ID
    Next Payload: None
    Reserved: 00
    Payload Length: 24
    Data (In Hex):
      c0 00 00 00
Feb 21 16:18:01 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Feb 21 16:18:01 [IKEv1] : IP = 38.98.146.1, Queuing KEY-ACQUIRE messages to be p
rocessed when P1 SA is complete.
all
Herbert Baerten
It seems that this device is initiating the tunnel, it sends IKE MM1 but it never receives a response from the peer.
ory (struct &0x37ceaf8)  , :  MM_DONE, EV_ERROR-->MM_WAIT_MSG2, EV
V_RETRY
indicates that we give up when waiting for the response...
Check if the peer is reachable, if the ISP (yours or the peer's) is not blocking UDP500, if the peer has IKE enabled, ... run debugs on the peer to see if it receives MM1 and why it does not respond...
hth
Herbert
