02-10-2019 10:36 PM
Hi all,
I am trying to configure a route-based VPN with Microsoft Azure. I was reading the document in the link below:
In this document, VTI interface IP has been set with a /31 subnet mask. From azure portal, a suggested configuration for on-premises device can be generated which also suggest to set the VTI interface IP with a /31 subnet. I tried to google it but could not find anything definitive.
Could someone explain why /31 subnet mask is suggested here?
Thanks in advance and apologies if similar discussion was already here before that I could not find.
Solved! Go to Solution.
02-11-2019 10:01 PM
02-10-2019 11:04 PM
02-10-2019 11:16 PM
Thanks for your reply.
So its not mandatory or anything. And I can use any subnet mask I prefer?
02-11-2019 10:01 PM
02-12-2019 08:36 PM
