tacacs+ config problem.
ROBERT TOGONON
Hi, I just started to setup an ACS 3.0 server from our lab network for testing. I must have miss something on the switch. When I try to console or telnet to the switch if would ask for username and password, but it gives me a authentication failed message. I need help on bypassing the "username and password" through the console port so I can look at the configuration of the switch. Thank you...RT
rsissons
Level 5
Level 5
The following URL on password recovery should answer your question -
http://www.cisco.com/warp/customer/474/index.shtml
Thank you, that help.
