12-02-2010 05:57 AM
I have a problem to initiate the tunnel from the router side. If i do a ping to the other side i can on the router the ipsec sa but there are send errors. If i ping from ASA side the tunnel is comming up sucessfully without any problems.
Additional i want to tell you we want to use the router also for internet access with ativated NAT.
Here is the configuration on router side:
version 12.4
no service pad
service timestamps debug datetime
service timestamps log datetime localtime
service password-encryption
hostname xxxx
boot-start-marker
boot system flash c837-k9o3sy6-mz.124-3.bin
boot-end-marker
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting commands 15 default stop-only group tacacs+
aaa session-id common
resource policy
clock timezone GMT 0
ip subnet-zero
ip cef
no ip domain lookup
ip name-server 194.158.37.196
ip name-server 194.158.37.211
ip sla monitor responder
username GNOuser password 7 xxxxx
username wetmalta password 7 xxxxx
crypto isakmp policy 11
encr 3des
authentication pre-share
group 2
crypto isakmp key <keypassword> address <remote>
crypto ipsec transform-set wet esp-3des esp-md5-hmac
crypto map nolan 11 ipsec-isakmp
set peer <remote>
set transform-set wet
match address 120
bridge irb
interface Loopback0
description MCI management address
ip address 10.252.39.206 255.255.255.255
interface Ethernet0
description to WET internal Network Malta
ip address 10.252.39.185 255.255.255.252 secondary
ip address 10.xx.48.11 255.255.0.0
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Ethernet2
description VLAN to internal switch Port 4
no ip address
hold-queue 100 out
interface ATM0
bandwidth 1024
no ip address
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
dsl operating-mode auto
interface ATM0.80 point-to-point
bandwidth 1024
ip address 194.158.34.46 255.255.255.252
ip nat outside
crypto map nolan
pvc 8/80
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 194.158.34.45
ip http server
no ip http secure-server
ip nat inside source list 100 interface ATM0.80 overload
access-list 100 deny ip 10.13.0.0 0.0.255.255 10.11.0.0 0.0.255.255
access-list 100 deny ip 10.13.0.0 0.0.255.255 10.201.0.0 0.0.255.255
access-list 100 permit ip 10.13.0.0 0.0.255.255 any
access-list 120 permit ip 10.13.0.0 0.0.255.255 10.11.0.0 0.0.255.255
tacacs-server host 170.127.71.169
tacacs-server timeout 20
tacacs-server directed-request
tacacs-server key 7 0010120500540607062F1D1F
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner motd ^C
* Warning *
* THIS DEVICE IS PART OF A PRIVATE NETWORK *
* DISCONNECT IMMEDIATELY IF YOU ARE NOT AN AUTHORISED USER ! *
* Unauthorised access is prohibited *
* And may be punishable by law *
* This device is monitored for unauthorised access *
*****************************************************************^C
privilege exec level 15 tclsh
privilege exec level 0 traceroute
privilege exec level 0 ping
privilege exec level 0 show configuration
line con 0
exec-timeout 5 0
password 7 yyyy
no modem enable
line aux 0
exec-timeout 5 0
password 7 yyyyyy
line vty 0 4
exec-timeout 30 0
password 7 yyyyyyyyyy
scheduler max-task-time 5000
ntp clock-period 17179112
ntp server 170.127.71.166
end
I hope somebody can help me
12-02-2010 06:02 AM
You have a L2L tunnel between the router and ASA.
Can you do this test?
1. Clear the SAs on both ends.
2. Try to establish the tunnel from the router ''ping x.x.x.x source y.y.y.y'' x.x.x.x is the inside IP of the router and y.y.y.y the inside IP of the ASA
3. Check the ''sh cry isa sa'' to check for phase 1 being established
4. Check the ''sh cry ips sa'' for traffic through the tunnel
Federico.
12-02-2010 06:20 AM
Here is the output of these commands:
Cisco837#ping 10.13.48.11 source 10.11.11.15
Sending 5, 100-byte ICMP Echos to 10.11.11.15, timeout is 2 seconds:
Packet sent with a source address of 10.13.48.11
Success rate is 0 percent (0/5)
Cisco837#sh cry isa sa
dst src state conn-id slot status
asa.asa.asa.asa rrr.rrr.rrr.rrr MM_NO_STATE 2 0 ACTIVE (deleted)
asa.asa.asa.asa rrr.rrr.rrr.rrr MM_NO_STATE 1 0 ACTIVE (deleted)
Cisco837#sh cry ips sa
interface: ATM0.80
Crypto map tag: nolan, local addr rrr.rrr.rrr.rrr
protected vrf: (none)
local ident (addr/mask/prot/port): (10.13.0.0/255.255.0.0/0/0)
remote ident (addr/mask/prot/port): (10.11.0.0/255.255.0.0/0/0)
current_peer asa.asa.asa.asa port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 5, #recv errors 0
local crypto endpt.: rrr.rrr.rrr.rrr, remote crypto endpt.: asa.asa.asa.asa
path mtu 1500, ip mtu 1500
current outbound spi: 0x0(0)
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
12-02-2010 10:35 AM
So, if you do the same test but from the ASA side the tunnel works correct?
Can you do this test again with the commands:
debug cry isa
debug cry ips
Federico.
