using 2821 for VoIP and dial in with E1/PRI
Carsten Radke
I'm using a 2821 with CCM 5.1 for telephonie.
Now I would like to dial in to my network over the 2821, too.
I've put in a dialer, local pool and so on but all calls are identified as voice.
please help.
Carsten
paolo bevilacqua
this is your config guide:
http://cisco.com/en/US/products/ps6441/products_feature_guide09186a0080788070.html
my problem is to configure th PRI for connecting voice and data at the same time. I want to get voicecalls and isdn-dialin to my network.
Is it possible over the same Interface ?
That is exactly what the above documents explains, if you take the time to read it.
