Using ASA 5510 with L2L and L2TP VPNs
bubaconk85
I would like to allow my remote users to access all resources bhind the ASA and my remote branches.
Here is my setup.  ASA5510 as hub at datacenter.
                              Internal network 172.21.x.x Directly connected
                              DMZ 172.22.1.x.x Directly Connected
                              Branch1 10.47.x.x L2L VPN
                              Branch2 10.47.y.x L2L VPN
                              Remote users 172.21.y.x L2TP Windows Client
I can access my internal resources connected to the ASA but not the DMZ or branch offices. Do I need routing and reverse route injection?Untitled.jpg
You also need to configure hairpinning.  http://goo.gl/vLqAR
Mohamed Sobair
Level 7
Level 7
You need to have (Spilit-tunneling) in the group policy for your remot branches and DMZ Networks as well.
and you need to exclude your remote users VPN from the NAT on the ASA.
If you post relevant config , it would be better.
Mohamed
Here is the sanitized partial config.  I tried the split tunnel as you may see, but it did not work.  I will try it again, but if I NO NAT the remote users IP pool then the branch office will not have a route for the REMOTE_USER_NET and it is going to fail.  Can I NAT the REMOTE_USER_NET behind the DMZ interface or something?
Names
name 10.xx.0.0 Branch-Net
Name 172.xx.0.0 INSIDE_NET
Name 172.xy.0.0 DMZ_NET
Name 172.XX.1.0 REMOTE_USER_NET
Name 10.xx.15.0 Branch_One
Name 10.xx.10.0 Branch_Two
interface Ethernet0/0
nameif outside
security-level 0
ip address xxx.xxx.xxx.xxx 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address INSIDE_NET 255.255.255.0
ospf cost 10
interface Ethernet0/2
nameif DMZ
security-level 50
ip address DMZ_NET 255.255.255.0
ospf cost 10
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address MGMNT_NET 255.255.255.0
ospf cost 10
management-only
boot system disk0:/asa724-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name somenet.com
object-group service Web tcp
port-object eq www
port-object eq https
object-group service WWW tcp-udp
port-object eq www
object-group service RDP tcp
description RDP
port-object eq 3389
object-group service VPN-TCP tcp
group-object RDP
group-object Web
port-object eq ftp
object-group service DM_INLINE_TCP_1 tcp
port-object eq ftp
port-object eq www
object-group service DM_INLINE_TCP_5 tcp
port-object eq www
object-group service DM_INLINE_TCP_2 tcp
port-object eq 8000
port-object eq ftp
object-group network DM_INLINE_NETWORK_1
network-object host WWW_Production
network-object host WWW_Backup
object-group network DM_INLINE_NETWORK_2
object-group service DM_INLINE_TCP_6 tcp
port-object eq www
port-object eq 3389
object-group network DM_INLINE_NETWORK_5
object-group network DM_INLINE_NETWORK_6
network-object host SQL1
network-object host SQL_Backup
network-object host VSRVR
object-group service DM_INLINE_TCP_4 tcp
port-object eq 1433
port-object eq 3389
port-object eq www
port-object eq sqlnet
object-group service DM_INLINE_TCP_3 tcp
port-object eq 1433
port-object eq www
access-list outside_1_cryptomap extended permit ip INSIDE_NET 255.255.255.0 Branch_One 255.255.255.0
access-list outside_access_in extended permit tcp any host ExternalIP eq www
access-list outside_access_in extended permit tcp any interface outside object-group DM_INLINE_TCP_5
access-list outside_access_in extended permit tcp any host ExternalIP object-group DM_INLINE_TCP_6
access-list outside_access_in extended permit tcp any interface outside object-group DM_INLINE_TCP_2
access-list inside_nat0_outbound extended permit ip INSIDE_NET 255.255.255.0 Branch_Net 255.255.0.0
access-list inside_nat0_outbound extended permit ip INSIDE_NET 255.255.255.0 India-IDC 255.255.255.240
access-list inside_nat0_outbound extended permit ip INSIDE_NET 255.255.255.0 Client_Net 255.255.255.0
access-list inside_nat0_outbound extended permit ip INSIDE_NET 255.255.255.0 DMZ_NET 255.255.255.0
access-list inside_nat0_outbound extended permit ip INSIDE_NET 255.255.255.0 Mumbi-Net 255.255.254.0
access-list inside_nat0_outbound extended permit ip INSIDE_NET 255.255.255.0 REMOTE_USER_NET 255.255.255.0
access-list DMZ_nat0_outbound extended permit ip DMZ_NET 255.255.255.0 172.21.0.0 255.255.255.0
access-list DMZ_nat0_outbound_1 extended permit ip DMZ_NET 255.255.255.0 10.xx.0.0 255.255.0.0
access-list DMZ_nat0_outbound_1 extended permit ip DMZ_NET 255.255.255.0 India-IDC 255.255.255.240
access-list DMZ_nat0_outbound_1 extended permit ip DMZ_NET 255.255.255.0 172.21.0.0 255.255.255.0
access-list DMZ_nat0_outbound_1 extended permit ip DMZ_NET 255.255.255.0 Mumbi-Net 255.255.254.0
access-list DMZ_nat0_outbound_1 extended permit ip DMZ_NET 255.255.255.0 REMOTE_USER_NET 255.255.255.0
access-list DefaultRAGroup_splitTunnelAcl standard permit Branch_Two 255.255.255.0
access-list DefaultRAGroup_splitTunnelAcl_1 standard permit INSIDE_NET 255.255.255.0
access-list DefaultRAGroup_splitTunnelAcl_1 standard permit DMZ_NET 255.255.255.0
access-list DefaultRAGroup_splitTunnelAcl_2 standard permit INSIDE_NET 255.255.255.0
access-list DefaultRAGroup_splitTunnelAcl_2 standard permit 10.xx.10.0 255.255.255.0
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
vpn-tunnel-protocol l2tp-ipsec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value DefaultRAGroup_splitTunnelAcl_1
group-policy DfltGrpPolicy attributes
banner none
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
Ultimatly this was the solution, but I have to either add a route manually to my Windows L2TP route table or I must use the Default Route on the remote network which does not allow me to access the Internet at the same time as split tunneling should.  If I find the solution I will reply with that fix.
