using isdn as backup for frame-relay
sunnysunsz
following is the configurationg :
interface BRI0
ip address 192.168.201.38 255.255.255.0
encapsulation ppp
dialer idle-timeout 180
dialer map ip 192.168.201.1 name nflkk-gz2800 broadcast 02081370421
dialer map ip 192.168.201.2 name nflkk-gz2800 broadcast 02081370422
dialer map ip 192.168.201.3 name nflkk-gz2800 broadcast 02081370423
dialer load-threshold 1 either
dialer-group 1
isdn switch-type basic-net3
ppp authentication chap
ppp multilink
interface Serial0
description pvc-to-guangzhou
bandwidth 256
ip address 192.168.200.154 255.255.255.252
service-policy output pospolicy
encapsulation frame-relay IETF
backup delay 30 30
backup interface BRI0
frame-relay interface-dlci 100
frame-relay lmi-type ansi
map-class frame-relay pvcmoniter
frame-relay end-to-end keepalive mode request
when frame-relay pvc is down,the isdn line can't activated.
i just want use static route ,how can i solve this problem?
thanks
since you have configured your Frame Relay on the physical interface, the 'backup interface' indeed typically doesn't work. The easiest solution for your scenario would be to configure a subinterface:
interface Serial0
no ip address
interface Serial0.1 point-to-point
bandwidth 256
backup delay 30 30
Can you try and see if this works for you ?
GP
Thanks for your reply!
In the cisco document article ,the end-to-end keepalive
feature can solve this problem.Have you ever used this command before?
And would you mind telling me why the point-to-point subinterface is able to find the problem of pvc?
The Frame Relay End-to-End Keepalive feature works between peer Cisco communications devices only, this is a requirement. Do we have 2 Cisco end devices here? Also we need to have matching parameters at either end:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1830/products_feature_guide09186a0080087a58.html
I understand you want to stick to static routing, there is a newer feature called “Reliable static routing backup using object tracking” that can fit your requirements. For more info please refer to:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html#wp1071672
Thanks, Mak
