VPN 3.1 with XP problems
HEATH FREEL
I have successfully installed ver 3.1 of the client and have it working almost.
Dial up connections work and allow me to connect to my network via IP but WINS is not working - even though the WINS addresses have been successfully pushed down.
LAN connections - either cable or DSL seem to allow me to connect and authenticate but I cannot pass IP traffic. I have disabled all the Security parameters in XP but still no luck.
Has anyone else had a similar problem? Is there a fix?
Heath
15 Replies 15
"Your ipsec connection has been terminated":
I have a similar problem with XP. After connecting the VPN tunnel (ver. 3.5) over ADSL the connection are down after 1.02-1.07 min. with the message "your ipsec connection has been terminated".
If I make a new connection there is no problem with fall-out.
Please give me some advice >>pfj@ramboll.dk
/Peter
