VPN 3000 - netscreen 5xp lan to lan problem
sante.guzzo
I'm trying to setup a vpn lan to lan.
the tunnel is up but not traffic.
Here is the log from the cisco side:
28 03/02/2006 17:03:39.020 SEV=7 IKEDBG/80 RPT=4578 212.34.x.x
Group [212.34.x.x]
Found Phase 1 Group (212.34.x.x)
31 03/02/2006 17:03:39.020 SEV=7 IKEDBG/28 RPT=4584 212.34.x.x
Group [212.34.x.x]
IKE SA Proposal # 1, Transform # 2 acceptable
Matches global IKE entry # 2 Proposal (IKE-3DES-MD5)
34 03/02/2006 17:03:39.150 SEV=3 IKE/134 RPT=287 212.34.x.x
Group [212.34.x.x]
Mismatch: Configured LAN-to-LAN proposal differs from negotiated proposal.
Verify local and remote LAN-to-LAN connection lists.
53 03/02/2006 17:03:39.220 SEV=4 IKE/119 RPT=4310 212.34.x.x
Group [212.34.x.x]
PHASE 1 COMPLETED
56 03/02/2006 17:03:39.220 SEV=7 IKEDBG/82 RPT=4310 212.34.x.x
Group [212.34.x.x]
Starting phase 1 rekey timer: 21600000 (ms)
57 03/02/2006 17:03:39.230 SEV=5 IKE/35 RPT=926 212.34.x.x
Group [212.34.x.x]
Received remote IP Proxy Subnet data in ID Payload:
Address 192.168.1.0, Mask 255.255.255.0, Protocol 0, Port 0
60 03/02/2006 17:03:39.230 SEV=5 IKE/34 RPT=5452 212.34.x.x
Group [212.34.x.x]
Received local IP Proxy Subnet data in ID Payload:
Address 10.10.0.0, Mask 255.255.224.0, Protocol 0, Port 0
63 03/02/2006 17:03:39.230 SEV=5 IKE/66 RPT=4901 212.34.x.x
Group [212.34.x.x]
IKE Remote Peer configured for SA: L2L: netscreenl2l
64 03/02/2006 17:03:39.230 SEV=7 IKEDBG/27 RPT=4567 212.34.x.x
Group [212.34.x.x]
IPSec SA Proposal # 1, Transform # 1 acceptable
Matches global IPSec SA entry # 11 Proposal (L2L: netscreenl2l)
67 03/02/2006 17:03:39.230 SEV=7 IKEDBG/85 RPT=4567 212.34.x.x
Group [212.34.x.x]
IKE: requesting SPI! (Protocol=ESP)
69 03/02/2006 17:03:39.240 SEV=5 IKE/75 RPT=4528 212.34.x.x
Group [212.34.x.x]
Overriding Initiator's IPSec rekeying duration from 28800 to 3600 seconds
71 03/02/2006 17:03:39.240 SEV=7 IKEDBG/91 RPT=6001 212.34.x.x
Group [212.34.x.x]
Transmitting Proxy Id:
Remote subnet: 192.168.1.0 Mask 255.255.255.0 Protocol 0 Port 0
Local subnet: 10.10.0.0 mask 255.255.240.0 Protocol 0 Port 0
75 03/02/2006 17:03:39.240 SEV=7 IKEDBG/92 RPT=4528 212.34.x.x
Group [212.34.x.x]
Sending RESPONDER LIFETIME notification to Initiator
76 03/02/2006 17:03:39.280 SEV=7 IKEDBG/93 RPT=5974 212.34.x.x
Group [212.34.x.x]
Loading subnet:
Dst: 10.10.0.0 mask: 255.255.240.0
Src: 192.168.1.0 mask: 255.255.255.0
79 03/02/2006 17:03:39.280 SEV=4 IKE/49 RPT=5974 212.34.x.x
Group [212.34.x.x]
Security negotiation complete for LAN-to-LAN Group (212.34.x.x)
Responder, Inbound SPI = 0x1a76b567, Outbound SPI = 0x6216debe
87 03/02/2006 17:03:39.290 SEV=4 IKE/120 RPT=5975 212.34.x.x
Group [212.34.x.x]
PHASE 2 COMPLETED (msgid=eca65ef4)
Any suggestions ?
Best Regards,
Sante Guzzo
morgsizun
verify filters between the gateways and internet .
May be , you have to permit ESP between the VPN gateways.?
Hope this helps..
regards,
Morgan Sizun.
