VPN 3000 Series Power Consumption
jacob.uecker
Can anyone tell me what the current draw the VPN 3000 series concentrators are rated for? I see the wattage and voltage but I'm missing the amperage.
5220
Level 4
Level 4
If i remember physics, the power equals amperage multiplied with voltage.
P=A*V, so it is safe to say A=P/V :)
You can check Concentrator info page with links to desired informations/configurations: http://cisco.com/en/US/products/hw/vpndevc/ps2284/tsd_products_support_series_home.html
Please rate if this helped.
Daniel
I remembered that too, but given the numbers listed:
A = 50W / 110 V
= .5 amps?
That's way too low.
Thanks for the link, but I couldn't find it in there either.
Back of the device says 2A. Not sure why when:
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_7/getstart/gs1und.htm#wp1037857
says that it is ~.5A
It says:
?3005 = maximum 25 W (0.2A @ 120 VAC)
?3015-3080 = maximum 50 W (0.42A @ 120 VAC)
So maybe it is not used heavily. That is the maximum value.
Cheers,
Daniel
