VPN Client 3.0.2 wireless via Linksys Wireless Router help needed
shadowgallery
I am trying to get the VPN Client 3.0.2 to work with wireless nic card via a Linksys BEFW11S4. I have no problems getting the VPN client to work using my wired nic card, and the wireless nic works fine when not using VPN. I have forwarded ports (500, etc) to the appropriate IP for the nic card, depending on which nic I am using for VPN. But can not get the VPN to work with wireless nic. I am able to get login prompt and it says negotiating but then gets stuck. I am running on W2K and using Dell TrueMobile nic.
24 Replies 24
Are you using xp?
mine stopped working when i switched to a new xp pro laptop.
tspofford
John...Did you ever find a solution to this? I had no problem with a wireless VPN connection via my BEFW11S4 until the last time I did a firmware upgrade. I haven't been able to connect since then. My inquiry to Linksys was never answered.
Tim Spofford
Chiming in ... having the same problem using a Linksys BEFW11S4 Version 2, firmware 1.42.7. Getting stuck when negotiating security policies, with IKE "Malformed ..." error messages.
gfhamilton
Got this from Mark Halstead.
I was having this same problem. Recently, Linksys released a new
version of firmware (1.43 on 9/5/2002) that solved the issue for me.
I haven't tried this latest firmware - will soon as I get time.. thx Mark. -gh
Yup.. the latest firmware revision works.. You'll also see that in the release notes for the firmware - items 14.
Changed Ipsec pass-through function over a wireless connection. -gh
Thanks to Mark Halstead!! I tried the new firmware last night and IT WORKS!!!
The new firmware (1.43) worked for me as well. I first found the beta (1.42.9) and found it to work as well.
I noticed that the link to the beta firmware I posted earlier doesn't work anymore. The site appears to have been rebuilt. Here is the new link to get there.
http://www.evansconforti.com/befw11s4/
I tried the newest firmware (1.43) for the V2 router, but still have problem getting my VPN connection to work.
Symptom:
- Laptop running XP, VPN connection seemed to be made with server (whether through wireless or wired connection), but can't connect to the web sites
- Another desktop running 98SE, connected to the router, VPN connection works perfectly.
- Connect via phone line with laptop running XP, VPN connection runs perfectly.
Sounds like a problem with XP specifically? What OS's are you folks running when the firmware works for you?
Thanks!
I've been having this same problem for a couple of months. I have opened a TAC case and subsequent bug report. bug CSCdu36784
The firmware recommended only works
with BEFSW11S4 ver.2.
I and others have ver 1 hardware and are stuck with 1.42.7 that has not yet resolved the issue...
My version 1 worked with a new xp pro laptop when i went backwards to v 1.39.2.
