05-20-2005 07:01 AM - edited 02-21-2020 01:47 PM
I have 2611XM with VPN server. After connecting from PC with VPN Client I can ping only local addresses of router. I can't even ping other side of point-to-point link.
Below is part of router configuration:
version 12.3
service password-encryption
hostname Router
enable secret 5 <removed>
aaa new-model
aaa authentication login default group tacacs+
aaa authentication login no_tacacs enable
aaa authentication login userauthen group tacacs+
aaa authentication ppp default group tacacs+
aaa authorization exec default group tacacs+
aaa authorization network default group tacacs+ if-authenticated
aaa authorization network groupauthor local
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa session-id common
ip subnet-zero
ip cef
no ip domain lookup
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp keepalive 40 5
crypto isakmp nat keepalive 20
crypto isakmp client configuration group VPN-GROUP
key <removed>
domain <removed>
pool vpnpool
crypto ipsec transform-set vpncypset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set vpncypset
crypto map clientmap local-address Loopback98
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address initiate
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Loopback0
ip address 172.31.97.203 255.255.255.255
interface Loopback26
ip address 10.0.26.254 255.255.255.252
interface Loopback98
description VPN termination
ip address X.Y.Z.23 255.255.255.255
interface Loopback254
ip address 10.0.254.26 255.255.255.255
interface Tunnel98
description Internet VPN
ip address X.Y.Z.54 255.255.255.252
ip nat inside
tunnel source 10.0.254.26
tunnel destination 10.0.10.6
interface Tunnel99
description Main internet access
bandwidth 1024
ip address 10.0.26.81 255.255.255.252
ip nat outside
tunnel destination 10.10.0.3
tunnel mode ipip
interface FastEthernet0/0
description To other NET interface
ip address 172.31.99.253 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0
bandwidth 2048
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
interface Serial0/0.101 point-to-point
bandwidth 256
ip address 172.31.97.25 255.255.255.252
ip nat inside
frame-relay interface-dlci 101
interface FastEthernet0/1
description Local address
ip address 10.10.26.193 255.255.0.0
ip nat outside
duplex auto
speed auto
ip local policy route-map VPN_OUT
ip local pool vpnpool 172.31.89.1 172.31.89.254
ip nat inside source list OtherNetAccess_acl interface Tunnel99 overload
ip nat inside source static network 172.31.0.0 172.26.0.0 /16
ip nat outside source static 10.0.10.80 172.31.96.80
ip nat outside source static 10.4.1.200 172.31.96.200
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.26.82
ip route 10.0.26.0 255.255.255.0 10.10.0.2
ip route 10.4.1.0 255.255.255.0 10.10.0.1
ip route 172.31.89.0 255.255.255.0 X.Y.Z.53
ip route 172.31.96.80 255.255.255.255 10.0.26.82
ip route 172.31.96.200 255.255.255.255 10.10.0.1
ip access-list standard IN-MY-NET_acl
permit 172.31.96.0 0.0.0.255
permit 172.31.89.0 0.0.0.255
ip access-list standard VPN_OUT_acl
permit X.Y.Z.23
ip access-list standard OtherNetAccess_acl
permit 10.35.0.0 0.0.255.255
route-map IN-MY-NET permit 10
match ip address IN-MY-NET_acl
route-map VPN_OUT permit 10
description VPN Clients out
match ip address VPN_OUT_acl
set ip next-hop X.Y.Z.53
tacacs-server host 10.4.1.7 key 7 <removed>
line con 0
login authentication no_tacacs
line aux 0
line vty 0 4
session-timeout 25
password 7 <removed>
05-26-2005 11:17 AM
I see that RRI configration is missing in your router configuration. Reverser Route Injection is used to advertise your client's IP address to the internal LAN. After RRI is configured and when your client connects to the VPN server, the server installs a static route on the server. You then will have to redistribute this to your internal LAN so that the internal LAN devices can reach the VPN client. Once the client disconnects, this static route is removed.
Configure this under the group command;
key
domain
pool vpnpool
rri
Hope that helps.
