11-10-2003 10:49 AM - edited 02-21-2020 12:52 PM
I have a 5001 VPN Concentrator with a 10.x.x.x address on the inside. I can connect from my home where my netgear router provides me a 192.168.0.x address via DHCP. I can see all of my company's internal network without any problems. I have to use Network Address Translation Mode and Port 80 on the configuration of my VPN Client.
But if I go to the Holiday Inn, and Try to connect, I am provided 10.x.x.x address via DHCP from them, and I can not connect to the VPN at all if I have the VPN Client in NAT Mode with Port 80, and If I uncheck the NAT Mode and Try not using NAT then I can connect, but I am not able to use the resources inside my network. I.E. I cannot ping anything, even my securID server, but it lets me authenticate without any problems.
I have done some research, and have found some people with similar situations but on different types of VPN routers, and they are being told to enable NAT-T. The instructions I found say GoTo Configuation | System | Tunneling Protocols | IPSec | Nat Transparency screen and check the IPSec over NAT-T check box.
Maybe Im blind, or just not patient enough to look for it. I can't seem to find it. I am running Software Version VPN 5001 Concentrator V5.2.14. Maybe I need to update my firmware. Im not sure, but I would greatly appretiate any help that anyone could provide. It would be a huge hit if my sales staff could use the VPN from a hotel.
I realize my hardware is out date and end of life, but if anyone could help me with the above problem. I would be greatful.
Jason Bielenda
Security Directoy
Dynamic Details Inc
Sterling, VA 20166
11-14-2003 07:28 AM
Hi Jason,
Nat-t is not available on VPN5000, if they are mentioning to go to configuration | System...etc, they are mentioning a CVPN3000.
One thing that you might want to try is creating a different group for sales, where you will assign a different ip subnet for them, at the same time, you will include this "new" subnet to your LAN routing.
So when they connect from a Hotel, they will use this vpn group, when they connect regularly they could use both.
Hope it helps.
Arthur
11-14-2003 08:06 AM
Thanks for your response. That is not the news I wanted, but it definately puts some closure to my issue. I will try setting up a different IP scheme for my users. Thank you for you time and Information.
regards,
Jason Bielenda
