VPN Help!!!
woodjl1650
I have a Cisco ASA 5505 connected to a Cisco 3600 router that does the routing for my home lap network.  I am wanting to setup a VPN so I can access my network while I am at a remote location.  Attached is my network layout to show how I have things setup right now.  Any assistance would be awesome, thanks.
17 Replies 17
No worries ! you have default pointing to the asa so you dont need any other routes.  This should work fine for you , make sure you dont have any MTU issues now when accessing anything from remote location.
I think you are good to go
Manish
Finally able to test my VPN connection, I am able to connect, but I don't have access to my network.  Does is matter that all I use my ASA for is a firewall?  I have the cable modem going into the ASA and routing the ASA to my Cisco 3660 Router, does that have anything to do with it?  Here is my current running config:
ASA Version 8.2(3)
hostname ciscoasa
domain-name wood.homeesrv.com
enable password DQucN59Njn0OjpJL encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
dns-guard
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.2.1 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address dhcp
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
 name-server 8.8.8.8
 name-server 8.8.4.4
access-list inside_nat0_outbound extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.240
access-list VPNWoodHome_splitTunnelAcl standard permit 192.168.2.0 255.255.255.0
access-list WoodVPN_splitTunnelAcl standard permit 192.168.2.0 255.255.255.0
pager lines 24
logging enable
logging asdm warnings
mtu inside 1500
mtu outside 1500
ip local pool HomeVPN 192.168.3.0-192.168.3.10 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
router rip
 network 192.168.1.0
 network 192.168.2.0
 network 192.168.3.0
 default-information originate
 version 2
route outside 0.0.0.0 0.0.0.0 174.56.139.1 1
route inside 192.168.1.0 255.255.255.0 192.168.2.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server VPN protocol radius
http server enable
http 192.168.2.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map inside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map inside_map interface inside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
 authentication pre-share
 encryption 3des
 hash sha
 group 2
 lifetime 86400
client-update enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 8.8.8.8 8.8.4.4 interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
 enable inside
 enable outside
group-policy WoodVPN internal
group-policy WoodVPN attributes
 dns-server value 192.168.1.14 8.8.8.8
 vpn-tunnel-protocol IPSec webvpn
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value WoodVPN_splitTunnelAcl
 default-domain value wood.homeserv.com
username Jonathan password WsMCHUiqvEuA9Gmb encrypted privilege 15
tunnel-group WoodVPN type remote-access
tunnel-group WoodVPN general-attributes
 address-pool HomeVPN
 default-group-policy WoodVPN
tunnel-group WoodVPN ipsec-attributes
 pre-shared-key *****
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:678222d40879101186c4fbb7308df576
: end
Hi Jonathan,
From the configuation of the ASA, i see that you are using RIP for routing, and you are advertizing the 192.168.3.0 network (with respect to the vpn pool). Now this should settle the routing requirement for the internal router, to point to the ASA for vpn traffic. The other possible thing that could cause issues with the internal network access would be that, there could be access-lists on the interfaces of the router behind the ASA that could be blocking the vpn traffic. Please check the access-lists on the ASA.
Also u can do a small test by doing a ping from your vpn client to the inside interface of the ASA, and see if packets reach the ASA. Plz paste the output of "sh cry ipsec sa" from the ASA after you connect to the ASA via vpn.
Let me know if this helps,
Cheers,
Rudresh V
