Vpn ipsec-tunnel-flow drop flow is denied by configured rule-VPN IPSec ikve1
I have problems with IPsec VPN ikve1.
My ASA 5525-x version 9.8(1)
My local lan: 172.16.17.0/24
IP VPN Pool: 10.60.60.0/24
I have 2 outsite interface: wan1, wan2. I have successfully tested VPN on wan1 ipsec vpn and ping access local ok.
But VPN wan2 also configures that VPN is successful but not access or ping local.  I am unable to ping from the outside from a network 10.60.60.0 /24 coming in on the outside interface to the inside network 172.16.17.0 /24
I have nat pool vpn and split network ok vpn
I have attached a file of my configuration on the ASA and used packet-tracer to discover where the problem lies, reproduced below:
Log WAN1=>ok
ASA01# packet-tracer input wan2 icmp 10.60.60.13 8 0 172.16.17.70 detail$
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
Additional Information:
found next-hop 10.10.10.253 using egress ifc  inside900
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
nat (inside900,wan2) source static Net17_ServerGroup Net17_ServerGroup destination static Net60-IPSEC-VPN Net60-IPSEC-VPN no-proxy-arp route-lookup
NAT divert to egress interface inside900
Untranslate 172.16.17.70/0 to 172.16.17.70/0
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group WAN2-ACCESS-IN in interface wan2
access-list WAN2-ACCESS-IN extended permit icmp any any
 Forward Flow based lookup yields rule:
 in  id=0x7f37566e88c0, priority=13, domain=permit, deny=false
        hits=3081, user_data=0x7f374b1dd080, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
        src ip/id=0.0.0.0, mask=0.0.0.0, icmp-type=0, tag=any
        dst ip/id=0.0.0.0, mask=0.0.0.0, icmp-code=0, tag=any, dscp=0x0
        input_ifc=wan2, output_ifc=any
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class-default
 match any
policy-map global_policy
 class class-default
  set connection decrement-ttl
service-policy global_policy global
 in  id=0x7f375876c910, priority=7, domain=conn-set, deny=false
        hits=2093301, user_data=0x7f3758768780, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 10.60.60.13/0 to 10.60.60.13/0
 in  id=0x7f375a1b3860, priority=6, domain=nat, deny=false
        hits=1358, user_data=0x7f37591755b0, cs_id=0x0, flags=0x0, protocol=0
        src ip/id=10.60.60.0, mask=255.255.255.0, port=0, tag=any
        dst ip/id=172.16.17.0, mask=255.255.255.0, port=0, tag=any, dscp=0x0
        input_ifc=wan2, output_ifc=inside900
Phase: 6
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
 in  id=0x7f3755491d00, priority=0, domain=nat-per-session, deny=true
        hits=10271334, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
        input_ifc=any, output_ifc=any
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x7f375621f320, priority=0, domain=inspect-ip-options, deny=true
        hits=10896907, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
 match default-inspection-traffic
 class inspection_default
  inspect icmp
 in  id=0x7f37584aeed0, priority=70, domain=inspect-icmp, deny=false
        hits=117819, user_data=0x7f37584abd90, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
 in  id=0x7f3758757f50, priority=70, domain=inspect-icmp-error, deny=false
        hits=117819, user_data=0x7f3758754e10, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 10
Type: INSPECT
Subtype: inspect-ftp
Result: ALLOW
Config:
 match any
 class class-default
  inspect ftp
 in  id=0x7f3758258c20, priority=70, domain=inspect-ftp, deny=false
        hits=1794292, user_data=0x7f3758256400, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 11
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
 in  id=0x7f3757ec02c0, priority=13, domain=ipsec-tunnel-flow, deny=true
        hits=1845726, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 12
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
 out id=0x7f37582b9750, priority=6, domain=nat-reverse, deny=false
        hits=1350, user_data=0x7f375669e420, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 13
Type: USER-STATISTICS
Subtype: user-statistics
Result: ALLOW
Config:
 out id=0x7f37582510e0, priority=0, domain=user-statistics, deny=false
        hits=15802004, user_data=0x7f3757fe96d0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=any, output_ifc=inside900
Phase: 14
Type: NAT
Result: ALLOW
Config:
 Reverse Flow based lookup yields rule:
        hits=10271336, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 15
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x7f375648a550, priority=0, domain=inspect-ip-options, deny=true
        hits=16184830, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=inside900, output_ifc=any
Phase: 16
Result: ALLOW
Config:
 out id=0x7f375824b320, priority=0, domain=user-statistics, deny=false
        hits=10443913, user_data=0x7f3757fe96d0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=any, output_ifc=wan2
Phase: 17
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 16313232, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_inspect_icmp
snp_fp_punt <inspect_ftp>
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: wan2
input-status: up
input-line-status: up
output-interface: inside900
output-status: up
output-line-status: up
Action: allow
LOGS=>VPN WAN2=> drop
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
        hits=3075, user_data=0x7f374b1dd080, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
 match any
 class class-default
        hits=2092504, user_data=0x7f3758768780, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
        hits=1357, user_data=0x7f37591755b0, cs_id=0x0, flags=0x0, protocol=0
Phase: 6
Type: NAT
Result: ALLOW
Config:
        hits=10270522, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
        hits=10895655, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: CP-PUNT
Subtype:
Result: ALLOW
Config:
 in  id=0x7f37581c7540, priority=79, domain=punt, deny=true
        hits=1, user_data=0x7f375508c7f0, cs_id=0x0, flags=0x0, protocol=0
        src ip/id=10.60.60.13, mask=255.255.255.255, port=0, tag=any
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect icmp
        hits=117808, user_data=0x7f37584abd90, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 10
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
        hits=117808, user_data=0x7f3758754e10, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 11
Type: INSPECT
Result: ALLOW
Config:
 match any
 class class-default
  inspect ftp
        hits=1793759, user_data=0x7f3758256400, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 12
Type: VPN
Result: DROP
Config:
 in  id=0x7f375a19a380, priority=69, domain=ipsec-tunnel-flow, deny=false
        hits=1, user_data=0x2e8adc, cs_id=0x0, reverse, flags=0x0, protocol=0
Result:
input-status: up
output-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
9 Replies 9
Francesco Molino
I didn't looked yet at your config files. But your packet-tracer are the same executed from ASA01 with different results. Can you explain please your detailed issue?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
HI Francesco Molino,
I have two wan outsite: wan1 and wan2 on the a ASA 5525-x. I executed on the same ASA01
I have configuration VPN Ipsec Ikev1.
I dialed vpn on wan1=> successfull and ping local access
Local Lan : 172.16.17.0/24
remote VPN: 10.60.60.0/24.
But I dialed VPN on wan2=> VPN sucessfull but i can not ping and access local lan.
This two capture log vpn wan 1=> ok
Log wan2=> ok my issue Phase 12 VPN
Phase: 12
Type: VPN
Result: DROP
Config:
I don't know reason
I understood that wan 2 is problematic whereas wan 1 is ok. But in your captures you're sharing 2 packet-tracer using wan 2 and this is where i don't understand.
Do you use multi context? Can you share your config please?
Francesco
Hi Francesco Molino,
I use single Context.
I attach my config asa detailed
thanks
Where did you attach your config? I don't see your file.
Francesco
Dear Francesco Molino
My config attachment
thanks very much
Can you connect 2 machines to VPN (1 over wan1 and 1 over wan2) please?
Then do a show route and share the output please.
Do a packet-tracer for both wan interfaces because last time you did only from 1 wan.
Also you have some nat that need to be reviewed:
nat (wan2,inside900) source static any any destination static interface H-VFCSRVFTP01 service FTP21 FTP21
nat (wan2,inside900) source static any any destination static interface H-VFCSRAPPISQL service SQL14333 SQL1433
nat (wan2,inside900) source static any any destination static interface H-VFCHDNVR08ET service NVR45678 NVR34567
nat (wan2,inside900) source static any any destination static interface H-VFCSRVFTP01 service WEB80 WEB80
You have to invert them the other way around like inside900 as source and wan2 as destination or use object nat. This is the way you need to build your nat statements when you want to expose some services to outside world.
Francesco
Hi These command is command open port NAT from inside to public outside, It does not invole vpn my issue. nat (wan2,inside900) source static any any destination static interface H-VFCSRVFTP01 service FTP21 FTP21 nat (wan2,inside900) source static any any destination static interface H-VFCSRAPPISQL service SQL14333 SQL1433 nat (wan2,inside900) source static any any destination static interface H-VFCHDNVR08ET service NVR45678 NVR34567 nat (wan2,inside900) source static any any destination static interface H-VFCSRVFTP01 service WEB80 WEB80 Thanks
I'm not saying these nats are the issue but just a remark. Have you connected the 2 machines at the same time and exported the output i asked to be able to troubleshoot further?
Francesco
