VPN Problem between Cisco and Check Point
fjmendonca
Guys,
I am with problems to establish a tunnel vpn site-to-site between one router Cisco 3660 e one firewall checkpoint NG AI R55.
In the SiteA is an environment with one router Cisco 3660 using the following configurations:
crypto isakmp policy 1
hash md5
authentication pre-share
group 2
lifetime 86400
crypto isakmp key [removed] address 172.17.10.111
crypto ipsec transform-set serasa esp-des esp-md5-hmac
crypto map serasa 1 ipsec-isakmp
set peer 172.17.10.111
set transform-set serasa
match address 101
interface Serial5/4
bandwidth 64
ip address 192.168.163.6 255.255.255.252
no ip unreachables
no cdp enable
crypto map serasa
ip route 10.12.0.155 255.255.255.255 192.168.163.5
ip route 172.17.10.111 255.255.255.255 192.168.163.5
ip route 172.17.10.155 255.255.255.255 192.168.163.5
access-list 101 permit tcp host 172.248.7.200 10.12.0.0 0.0.255.255 eq 3315
In the SiteB we have one environment with high availability Nokia using VRRP.
The IP address configured as cluster in the Check Point is 172.17.10.111.
We already confirm all the configurations of phase 1 and 2 and is OK, but the VPN does not establish.
The following messages appear in the router and firewall:
ROUTER
Jun 15 10:39:24 Orbital: ISAKMP (0:252): Checking IPSec proposal 1
Jun 15 10:39:24 Orbital: ISAKMP: transform 1, ESP_DES
Jun 15 10:39:24 Orbital: ISAKMP: attributes in transform:
Jun 15 10:39:24 Orbital: ISAKMP: encaps is 1
Jun 15 10:39:24 Orbital: ISAKMP: SA life type in seconds
Jun 15 10:39:24 Orbital: ISAKMP: SA life duration (basic) of 3600
Jun 15 10:39:24 Orbital: ISAKMP: SA life type in kilobytes
Jun 15 10:39:24 Orbital: ISAKMP: SA life duration (VPI) of 0x0 0x46 0x50 0x0
Jun 15 10:39:24 Orbital: ISAKMP: authenticator is HMAC-MD5
Jun 15 10:39:24 Orbital: ISAKMP (0:252): atts are acceptable.
Jun 15 10:39:24 Orbital: IPSEC(validate_proposal_request): proposal part #1,
(key eng. msg.) INBOUND local= 192.168.163.6, remote= 172.17.10.111,
local_proxy= 172.248.7.200/255.255.255.255/0/0 (type=1),
remote_proxy= 10.12.0.0/255.255.0.0/0/0 (type=4),
protocol= ESP, transform= esp-des esp-md5-hmac ,
lifedur= 0s and 0kb,
spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x2
Jun 15 10:39:24 Orbital: IPSEC(kei_proxy): head = serasa, map->ivrf = , kei->ivrf =
Jun 15 10:39:24 Orbital: IPSEC(validate_transform_proposal): proxy identities not supported
Jun 15 10:39:24 Orbital: ISAKMP (0:252): IPSec policy invalidated proposal
Jun 15 10:39:24 Orbital: ISAKMP (0:252): phase 2 SA policy not acceptable! (local 192.168.163.6 remote 172.17.10.111)
Jun 15 10:39:24 Orbital: ISAKMP: set new node 2114856837 to QM_IDLE
Jun 15 10:39:24 Orbital: ISAKMP (0:252): sending packet to 200.245.207.111 my_port 500 peer_port 500 (I) QM_IDLE
Jun 15 10:39:24 Orbital: ISAKMP (0:252): purging node 2114856837
Jun 15 10:39:24 Orbital: ISAKMP (0:252): Unknown Input for node -528822595: state = IKE_QM_I_QM1, major = 0x00000001, minor = 0x0000000C
Jun 15 10:39:24 Orbital: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 172.17.10.111
FIREWALL
IKE: Main Mode Received Notification from Peer: Initial Contact
IKE: Main Mode completion.
IKE: Quick Mode Received Notification from Peer: no proposal chosen
Ike: Informational Exchange Received Delete IKE-SA from Peer:
Somebody has idea of which can be the problem?
Thank you for help.
Fabiano Mendonca.
cool. pls mark the case as solved which might help for others.. rate replies if found useful..
Raj
sachinraja
Level 9
Level 9
Hello Fabiano,
I can see an error proxy identities not supported on your router.. this can basically happen due to the mismatch of interesting traffic parameters on both the ends... your router has a crypto ACL
make sure the other end has exactly reversed ACL for crypto.. otherwise make necessary changes.. why cant u try with a permit ip host 172.248.7.200 10.12.0.0 0.0.255.255 on your crypto ACL ??
do let us know if it works out..
Raj
Hello Raj,
I removed "eq 3315" and changed the access-list to:
access-list 101 permit ip host 172.248.7.200 10.12.0.0 0.0.255.255
Then, the VPN functioned.
Thank you very much.
Fabiano
Raj
