vpn / tunel problem, really need help!
k.perryman
I have a cisco827 and a 3005 concentrator. I have been trying to use the web based CRWS config tool on the router. When I click on "easyvpn" and fill out the first page I then go to the second page and get prompted for "username, password and domain". I have two blocks in which to enter the data but I am not sure what to enter or how to enter it. I am using nt domain authentication so I am assuming that I put in my domain account and password, if this is correct where do I put in the domain name? and how do I put it in? after the password using some special character I am thinking but at this time I am really needing some help. For what it is worth, I then go into the console port of the router and it is constanlty screaming for a username, password, and domain, again how do I enter it?
gfullage
If you've set up the 3005 to do NT authentication, and the 827 is asking for a password, all you should need to enter is the username and password, don't worry about the domain name.
On the 3005 you've specified the PDC/BDC to send the authentication request off to, and as long as your NT domain structure has the correct trust relationships, then your username/password should be authenticated successfully.
