04-16-2013 06:05 AM
Hi all,
We have VTI tunnels between Cisco (3825 and 878) and Juniper (SRX3600).
Sometimes tunnel is going down and I should manualy shutdown and no shutdown tunnel interface to bring it up.
This is logs from Cisco:
%%crypto-4-recvd_pkt_inv_spi: decaps: rec'd ipsec packet has invalid spi for destaddr=X.Y.100.200, prot=50, spi=0xc5d07a33(3318774323), srcaddr=X.Y.100.100
%%crypto-4-ikmp_no_sa: ike message from X.Y.100.100 has no sa and is not an initialization offer
X.Y.100.100 is Juniper SRX3600
X.Y.100.200 is Cisco 3825
But I see this logs more often, than tunnel is going down!
So what is problem?
04-16-2013 06:11 AM
this should help #crypto isakmp invalid-spi-recovery
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a0080bf6100.shtml
Best Regards
Please rate all helpful posts and close solved questions
04-25-2013 06:19 AM
Thanks for reply,
I added crypto isakmp invalid-spi-recovery on Cisco 3825, but tunnel interface still is going down.
04-29-2013 01:13 AM
make sure your phase 1 and 2 parameters are matching on both ends, try to disable the pfs if you have it enabled, try to enable the keepalive, see if these can help.
