WEB VPN (SSL VPN) problem
sulap
Hi everybody.
I hawe problem with SVC and with router 3845 (12.4(15)T1). I can connect to my gateway and i can successfully login and start SVC and for a while is everything O.K.. Traffic is passing through the tunnel. But after a while, client is disconnected and on router is message on 3 lines:
WV-TUNL: Severity ERROR Type CLOSE_ERROR
WV-TUNL: Text: Detected error in SG protocol
Mar 10 20:23:37.724: WV-TUNL: Call close function due to error
With this is affected only one client.
Have you any idea?
Thanks and regards.
bwilmoth
Level 5
Level 5
You may be hitting with this bugCSCsb19268
Hi, Thank You very much for your idea. My release of SVC is 1.1.4.176. Bug was resolved in release 1.0.2, but I will try 1.1.4.179 - it is last release.
