Acceptable Use Control Engine data version on the WSA does not match the version on the Management Appliance
axel-ironport
Community Member
Dear all,
I have the situation that 7 out of 19 WSAs managed by one SMA show the message:
Acceptable Use Control Engine data version on the Web Appliance does not match the version available on the Management Appliance.
Update Type Web Appliance Version Management Appliance Version
Web Categorization Categories List 0 1505772357
When checking the Acceptable Use Controls, the 7 appliances are up to date.
Also manually updating again does not solve the issue.
Any ideas?
Thanks in advance for your support.
Handy Putra
Can you check on all 19 WSAs, are they all on the same versions of Web Categorisation list?
If they are not, better update them to be using exact same version. Then perform publish again from SMA to any WSA that successfull for the SMA to fetch the updated version.
Also are they using the sam CM (configuration master) version?
Best Regards
Handy Putra
Hi Handy,
sorry for my late reply, I was not available last week. The issue is no longer existing. All WSAs are updated now. Funny thing is, that it have been 7 WSAs around the world that have not been updated properly.
For now, this is settled.
Thanks anyway.
