Application is not working while going through Ironport S370
ranjith.kanisan
We have deployed the Ironport as wccp trasperant mode and using software version is 7.1.3.
We are configured one application url in Allowed custom url categories, but we are not able to access the application when its traffic is flowing through the ironport . After we created the bypass policy for that url application is responding properly for the client request. When we are doing the policy trace(all the time, with or without bypass policy) for the url we are getting ERR GATEWAY message. Please find the below mentioned policy trace output.
User Information
User name: None
Group Membersip: None
User Agent: mozilla 4.0
Custom url category : Allowed
Policy match
Iron port data security policy : None
Decryption policy: None
Routing policy : Global routing policy
Identity policy: No Authentication
Access policy: No Authentication policy
Final Result
Request Blocked
Details: ERR GATEWAY
Trace session complete
Kindly suggest why this error is happening ? and How can i use the application through proxy with out doing the bypass settings.
Thanks in Advance
Ranjith
Chris Illsley
Level 3
Level 3
Hi Ranjith,
An ERR_GATEWAY would imply that the application is being resolved but is not reachable, if it's using non-standard ports you may want to check your firewall.
Chris
Chris Illsley
Level 3
Level 3
Hi Ranjith,
Chris
Christian Rahl
Are you using L4TM? If so please check your L4TM logs for the domain you are trying to access.  ERR_GATEWAY can indicate L4TM is blocking the website.
Christian Rahl
Customer Support Engineer
Cisco IronPort - Web Security Appliances
Cisco Technical Assistance Center RTP
United States Ironport: 1-877-641-IRON (4766)
