Regular Expression
Joe Silver
Hello! Quick question ... When doing GREP from a cli what's the correct syntax to search for a particular ip address in the access log? I've tried the ip address, ip address in double quotes and single quotes but they either return empty search results or results that seem to match the first ocet only. I even tried a slash in front of the period but that doesn't work either.
Thanks!
Joe
ent from Cisco Technical Support iPhone App
The issue is the periods in the IP.  A period will match any character in place of the period. For IP's type this in 10\.10\.6\.7 This is escaping the periods telling grep to look for the characater itself.
Christian Rahl
Customer Support Engineer
Cisco IronPort - Web Security Appliances
Cisco Technical Assistance Center RTP
United States Ironport: 1-877-641-IRON (4766)
Chris Illsley
Level 8
Level 8
Easiest way is just to use the menu:
grep
IP address
Etc
However, grep ip-address accesslogs, should also work.
Chris
Thanks Chris for the response.  Unfortunately using the cli menu to grep an ip address out of the accesslogs doesn't seem to work.  I realize that doing GREP does a search as a regular expression but I just tried it again and the command does return results but none seem to match the ip addresses I'm searching for.  I've attached a screenshot.
If I grep for a single username or for a website it works just fine but doesn't work when grep'ing for an ip address.
Joe
Christian Rahl
Thanks Christian! That works great!
