ASA URL FILTER AND WCCP
Giorgio Romano
Hello to everybody,
I have a Cisco ASA with csc-ssm.
I need to configure wccp on the asa and I want to use csc-ssm for url filtering.
So the question is:
"May I perform the url filtering to the client requests using csc-ssm before they get the cache server?"
thank you very much
giorgio
Chetankumar Phulpagare
Please check this link: http://www.cisco.com/c/en/us/td/docs/security/asa/asa91/configuration/general/asa_91_general_config/basic_wccp.html#37863
Especially this part:
  • "TCP intercept, authorization, URL filtering, inspect engines, and IPS features are not applied to a redirected flow of traffic."
Packets classified for WCCP will not go through CSC-SSM but will be redirected to cache-server first. So you are better off doing URL filtering at cache server. Hope this helps!
Chetan
Chetan
Giorgio Romano
thank you very much for your answer!
GR
