AsyncOS 7.1 User Guide : URL categorisation : wrong abbreviation for category "Paranormal & Occult"
Laurent LE GOFF
According to Cisco Ironport AsyncOS 7.1 for Web User guide (November 2010), page 439, "URL Category Description for Cisco Ironport Web Usage Controls" :
URL Category : Paranormal & Occult
Abbreviation : nonm
=> This is false. When I do a test on a WSA running AsyncOS release 7.1.1-038 & using Cisco WUC license, the abbreviation tag returned in the accesslog is "para" and not "nonm"
1340195393.565  1273 10.10.200.4 TCP_MISS/200 3389 GET http://www.bermuda-triangle.org/assets/images/Arrow24thumb.gif - DIRECT/www.bermuda-triangle.org image/gif  DEFAULT_CASE_11-Bypass_authent-10.10.200.0-NONE-NONE-NONE-DefaultGroup  <IW_para,0.0,"0","-",0,0,0,"1","-",-,-,-,"-","1",-,"-","-",-,-,IW_para,-,"Unknown","-","Unknown","Unknown","-","-",21.30,0,-,"-","-">  -
5 Replies 5
sfiebran
thank you for pointing out. The good news are, starting with 7.5 this category already got revised and is not anymore a standalone category.
Thanks again,
-Stephan
Hello Stephan,
What is the last status regarding asyncos 7.5 release ? Is it still in FCS or is it finally in General Availability.
I see that the release note has changed since 18th June, the tag FCS has disappeared but I still do not see it in GA and I did not receive any notification regarding this.
Cisco IronPort AsyncOS 7.5 for Web Security Appliance
Hi Laurent,
7.5 is still FCS. Thank you for pointing out my error, I should be sure to put back on the FCS label for the 7.5 release notes on the website. We did release a new build for 7.5 that's FCS that should hopefully become GA before too long.
Cheers,
Jennie
Hi Jennie,
Thanks a lot for this feedback. Can you provide a more precise answer than "before too long" ?
Can I expect the GA to be delivered before the end of July ? end of August ?
This 7.5 release is in FCS since the 6th of March, so since more than 3 months now. Usually, your FCS releases never last more than one month, what is causing such delays here ? Are you facing some troubles with it ?
Hi Laurent,
I'm "just" a tech writer, so I'm not really authorized to talk about upcoming release dates.  (I don't want to upset our product managers!)   But I can tell you that if we're delaying a GA release it's because we're fixing bugs, so it's better to wait for a better quality product. =)  At some risk, I'll say that a guess of by late August is much safer than late July.  If you want more details, talk to your Cisco sales rep.
