Can an Ironport work in both WCCPv2 and L4 Traffic monitoring modes at the same time?
jfgobin01
Hello Ciscoers,
We have an ironport installed and we use WCCPv2 to redirect the traffic. And as it occurs, I have a need to forward the traffic for another network, that uses another path to the Internet.
So I was thinking using the L4 Traffic Monitoring.
To the best of your knowledge, is there a way to have the appliance use both WCCPv2 and L4 Traffic monitoring at the same time? From the configuration, it's one or the other.
J.
yao yu jiang
yes, but my problem is I can see the l4tm report and logs, but I did not receive the tcp-reset, the session is never tear down, I use the switch span port
Ok. I'll try.
As a matter of fact, I plan to use policy-based routing to forward all the "interesting" traffic to the appliance.
For your TCP-Resets not seen, do you allow ingress on the span session?
J.
yes, I have span destination port ingress set,
I can see the icmp unreachable packet, but not tcp reset packet.
