05-02-2011 07:49 AM
Hello Ciscoers,
We have an ironport installed and we use WCCPv2 to redirect the traffic. And as it occurs, I have a need to forward the traffic for another network, that uses another path to the Internet.
So I was thinking using the L4 Traffic Monitoring.
To the best of your knowledge, is there a way to have the appliance use both WCCPv2 and L4 Traffic monitoring at the same time? From the configuration, it's one or the other.
J.
05-02-2011 08:47 AM
yes, but my problem is I can see the l4tm report and logs, but I did not receive the tcp-reset, the session is never tear down, I use the switch span port
05-02-2011 09:00 AM
Ok. I'll try.
As a matter of fact, I plan to use policy-based routing to forward all the "interesting" traffic to the appliance.
For your TCP-Resets not seen, do you allow ingress on the span session?
J.
05-02-2011 10:42 AM
yes, I have span destination port ingress set,
I can see the icmp unreachable packet, but not tcp reset packet.
