Changing wsa data ip
SIB9
Frequent Visitor
Frequent Visitor
Hi all,
We had WSA appliance and we are migrating appliance to virtual environment.
We have configured new WSA and tested and its working fine and now we are planning to move it to LIve so we are planning to change the data ip.of new virtual WSA to the old appliance WSA data Ip.(p1)
We can change it without resetting the vm right.
All devices in our environment is using the old ip in windows configuration thats y.
2 Accepted Solutions
balaji.bandi
Sure make sure you remove OLD appliance from network.
Make sure the P1 interface belong to that VLAN
Reconfigure your network settings of P1 and test it,
Sure i have done many Migration it straight forward, depends on how your approach is  there will be small brief of network connection from client to internet, when you shutdown old WSA IP to bring up on the new WSA.
BB
amojarra
hi @SIB9
Yes, there is no need for reboot or ...
just please make sure, if there are any FQDNs which are in use in WSA, they should point to the correct IP.
I'm mostly talking about Authentication redirect URL. (if you are using)
Amirhossein Mojarrad
++++        If you find this answer helpful, please rate it as such      ++++
balaji.bandi
BB
Yaaaa we will be doing it in a downtime
The new ip is in another vlan but we have passed it in the network switch and vswitch of the host.
So it wont be any issue right
amojarra
hi @SIB9
SIB9
Frequent Visitor
Frequent Visitor
Sure we will do that and update
