Cisco Iron Port explicit mode
mohamed fayz
hai All,
I Have setup my ironport WSA in explicit mode, which is placed in ASA DMZ. All the Http,Https, ftp traffic are working fine. But, we have some applications, which is not using any of the above protocols. These applications are using some ports.So, how can i pass all these application to my WSA proxy, since the application doesnt know who is my proxy!!! any solution.
FAyz
2 Accepted Solutions
Chris Illsley
Level 3
Level 3
Not really, if the application can't be configured to use a proxy and doesn't pick it up from the PC settings it won't work.
Explicit mode requires the application to initiate connection to the proxy.
Chris
Additionally if the application is using the proxy settings but using some non standard port it might be blocked.  Verify the port is allowed to go through by checking the Web Security Manager -> Access Policies -> Protocols and User Agents -> HTTP Connect ports.  If the port is not allowed in there, it will not allow the application to create a connection.
Christian Rahl
Customer Support Engineer
Cisco Web Content Security Appliance
Cisco Technical Assistance Center RTP
Chris Illsley
Level 3
Level 3
Chris
Christian Rahl
