Cisco WSA how to make two proxy.pac at the same time with different ports
sergei-bilan
Hi team,
 How to make two proxy.pac at the same time with different ports.  For example, one user should give one Proxy.pac on port 1111 and another proxy1.pac on port 2222 as an example. Can this be done? Share your experience or documentation. Thanks in advance.
But how to do it? To bind other proxy.pac to other port not such as already existing proxy.pac and that they functioned simultaneously.
balaji.bandi
Yes you can host as many as PAC file, how you going to  deliver to Client browse is important here.
another way you can make PAC file as smart, if the user subnet XX do this, if user YY subnet do this, like if and but kind. in single PAC file too.
BB
Let's say my HTTP Ports to Proxy: 1111 is where in the settings do another HTTP Ports to Proxy: 2222? That is the question.
then ignore other answer of mine.
For this clarity, you can bind the proxy to different ports. make sure you have correct access policy for the users.
so if the user know other port can deny, some time users change the port to get better access.
BB
