Cisco WSA SFTP Forwarding Hosts Configuration
ezzaariyouness
Hello everyone ,
I'm trying to migrate SFTP   Forwarding Hosts Configuration from bleau coat Proxy to Cisco Web appliance, I didn't find any documentation To configure That.
Can You please help with That.
Best regards
Younes
balaji.bandi
Not sure we understand correctly "Cisco WSA SFTP Forwarding Hosts Configuration"
Can you explain more on this cotext to help better ?
Always suggest to use best deployment guide from vendor (this is old document but still the concept is same).
https://www.cisco.com/c/en/us/products/collateral/security/web-security-appliance/guide-c07-742373.html
BB
I'm planning to Proxy SFTP traffic to remote SFTP server .
amojarra
Hello @ezzaariyouness
Please be advised, if you are planning to Proxy SFTP traffic, WSA still not supporting that, you can check the workaround in this Enhancement request:
CSCvn16059 : Bug Search Tool (cisco.com)
Amirhossein Mojarrad
++++        If you find this answer helpful, please rate it as such      ++++
That what I'm planning to, Ok, I will see the workaround.
