Cisco WSA1000v with AD Integration issue
Dear Team,
we are trying to intigrate  out AD domains with WSA1000v and unable to intigrate below was error. please do the need full.
1. I'd set the source interface to management, and make sure you can reach those IPs from the management interface
2. Also make sure you have dns configured to point at your internal dns servers.
3. I'm fairly sure that the domain name has to be the DNS name of the domain, not just the netbios name
4. If you scroll down, I think there's a test button... what does that report?
________________________________
This email is intended solely for the use of the individual to whom it is addressed and may contain information that is privileged, confidential or otherwise exempt from disclosure under applicable law. If the reader of this email is not the intended recipient or the employee or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
If you have received this communication in error, please immediately notify us by telephone and return the original message to us at the listed email address.
Thank You.
@Ken Stieers Thank you for your prompt response. now its able join the domain. but facing other challenge while Migrating the hardware to Virtual so it's raising lot of errors. 1) is while importing licenses 2) is while loading the configuration guide. please find the attached snapshots and provide some positive response.
What options are you using when you import the config file?
If I remember correctly, the WSA allows you to import but ignore the interface section?
Try loading that, then reconfigure the interfaces to what you need.
Thank You.
What options are you using when you import the config file? : Importing from device
If I remember correctly, the WSA allows you to import but ignore the interface section? : i didn't see any if it is possible can you please share the link.
here are my findings in VM's:
1) existing hardware appliance has P1&P2(P2 is not using) but in virtual appliance i'm unable to see the P2 option only.
2)  although we created same firewall rules for virtual and existing hardware appliance. existing appliance is able to ping or nslookup to google.com but virtual wsa is unable to .
can you please provide and clear cut document for migration from hardware to Virtual. like what network configuration need to setup.
Thank you so much for your prompt response.......
