Configuring WCCP for http and https
cecato_ironport
Community Member
How do I configure wccp on a 6509 to redirect http and https trafic to a S650. I am using the following config and http is working fine:
ip wccp version 2
ip wccp web-cache redirect-list aclwccp
interface Vlan23
description Rede Firewall
ip address 10.0.23.20 255.255.255.0
ip access-group 172 out
ip wccp web-cache redirect out
mls rp vtp-domain coc_block1
mls rp ip
mls netflow sampling
end
Should I config an other service for the https protocol?
jowolfer
Level 7
Level 7
Cecato,
The WSA can be configured to send 80 and 443 traffic, in the WCCP settings area (5.2.0+). There are some things you will need to be aware of before doing this though:
1. If you are on 5.2.0-x, you will not be able to inspect HTTPS traffic. Only version 5.5.0+ has the ability to decrypt HTTPS traffic. Because of this, it is not recommended to redirect port 443 on WSA version 5.2.
2. You will most likely need to specify a service ID other then web-cache. On most Cisco devices, web-cache is reserved for port 80 traffic only and cannot be changed. Any other service ID will work as you want it to.
