Establish an SSH connection
schwager
Visitor
can someone tell me how to establish an SSH connection from my M650 management appliance to 2 wsa S650?
I have the feature keys but i always  get this message when i try to logon:
ErrorInvalid netstring returned: You are not authorized to login. You are not authorized to login.
Any ideas?
regards
jdohrman
This could be due to IP restrictions on who can login to the appliance.
You can try logging into the CLI locally and check for the following:
CLI > adminaccessconfig > IPACCESS
If you see:
Current mode: Restricted
...that would be the reason. You can set IPACCESS to 'ALL' with the same command. After wards you should see:
Current mode: Allow All.
Hope this helps!
Cheers,
Jakob
jdohrman
If you see:
Hope this helps!
Cheers,
Jakob
It works.
You are my hero.
regards
