Facing issue as WSA is not updating External Live Feed via auto update
Syed Vali Uddin
I have defined a custom & external URL category which will ingest sync with SOAR platform & synch with the external dynamic list hosted by SOAR platform.
As of now I have followed all the pre requisite steps & set time to 01:00 (HH:MM) to update feed but it’s not updating.
Although I have tested the file by GET FILE & it was successful.
I am also attaching a snap for reference
8 Replies 8
balaji.bandi
Do you have any changes in the network ?
check the Logs see is there any error? also check WSA can reach the Cisco site ?
follow below guide (may be check the IP may have changed)
https://www.cisco.com/c/en/us/support/docs/security/email-security-appliance/117854-technote-esa-00.html
BB
No changes in network.
WSA can reach the SOAR URL & GET FILE status is same as above, the main issue is that it is not updating automatically & status is shown as NEVER UPDATED for the feed
Try Manually see if you can able to pull the updates ?
BB
Syed Vali Uddin
when I open URL category, again submit it & commit changes I can see the updated entries.
you mean to now you can see the updates ?
BB
Syed Vali Uddin
yes but only via manually procedure. It is still not synching by auto update option
that is bizzard, you set up to run every hour, do you see any Logs ?
BB
amojarra
Hello
there are couple of things which I would like to ask you please :
[1] can you check displayalerts from CLI to see if there is any logs for your feed every hours.
[2] from CLI you can restart feed service : diagnostic > SERVICES > EXTFEED > RESTART
[3] also you can check the FEED_Logs in CLI , type grep then choose the number associated with
          "feedsd_logs" Type: "Feedsd Logs" Retrieval: FTP Poll
it will gives a better overview of what is happening
meanwhile could you please share the version of your WSA?
thanks again
Amirhossein Mojarrad
++++   If you find this answer helpful, please rate it as such  ++++
