FQDN resolution in ASA
Harmeet Singh
I have an ASA with below configuration:
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 4.2.2.2
object network MGMT_SERVER
host X.X.X.X
object network obj-eclipse.org
fqdn eclipse.org
object network obj-maven.apache.org
fqdn maven.apache.org
object network obj-java.com
fqdn java.com
object network obj-redhat.com
fqdn redhat.com
object-group network MGMT_FQDN
network-object object obj-eclipse.org
network-object object obj-maven.apache.org
network-object object obj-java.com
network-object object obj-redhat.com
access-list inside_access_outside extended permit tcp object MGMT_SERVER object-group MGMT_FQDN eq 443
access-list inside_access_outside extended permit tcp object MGMT_SERVER object-group MGMT_FQDN eq 80
access-list inside_access_outside extended permit udp object MGMT_SERVER host 8.8.8.8 eq domain
access-list inside_access_outside extended permit udp object MGMT_SERVER host 4.2.2.2 eq domain
The issue is, when I am resolving nslookup on my local server (MGMT_SERVER) for fqdn java.com then the resolved IP is different and my ASA resolving different IP when I check in dns-hosts. Due to this java.com is not accessible from the server.
Is there any solution for this problem.
Jennifer Halim
Is your ASA configured to use the same DNS servers as your local MGMT servers?
Hi Jennifer,
DNS is same on both devices. 4.2.2.2
Try to use a simpler service (not java, google, facebook).
The issue with big vendors is that they use a lot of IPs. I'll get IP X, you'll get IP Y and someone else IP Z even though we're using same DNS.
So one issue is the destination domain for which there are a lot of IPs and the other with the DNS server you're using that may not cache the response and just use the TTL from the authoritative server (google has 1 min TTL.
Do a quick test and you'll see it works (or it should):
Use something like www.k.ro (an old webserver), It's only one IP.
The solution would be to use an internal DNS server because of the caching. You're in control.
- both your ASA and your station would get the same response.
I don't know about google's DNS..
