FTD Application Block
dcanady55
Level 5
Level 5
I recently had some very high traffic by application risk come through, and I blocked this application A in my ACP. The first rule of this ACP is application blocks. Few days go by and dashboards show very high again, and when I open up context explorer, there's the application A I blocked. When I drill into the analysis and look at one of the connections in the application protocol, it shows QUIC, and under the client section, it shows the application A I blocked previously. I am looking into blocking QUIC, but I don't understand: if QUIC is using encryption so that the FTD does not see the application A I'm trying to block, how does the FTD know its the "client" and why is it not taking action to block this traffic?
Gustavo Medina
Would need to see the full logs to tell where FTD is detecting the app. In general what FW vendors are doing is blocking QUIC so that the browsers fallback to TLS so that they can decrypt it. On FTD newer versions, Encrypted Visibility Engine was added which has the ability to detect apps and processes without decrypting the traffic (https://secure.cisco.com/secure-firewall/docs/encrypted-visibility-engine). EVE will continue to increase the amount of apps it can detect. You can see this video to understand how EVE works and also look at the rule is often configured to block QUIC.
https://www.youtube.com/watch?v=0w-uozqq_gs
I know little about FTD but I will share with you all I know
there is AppID in FTD traffic flow and it check the AppID before and after SSL encryption.
Gustavo Medina
