How to clear existing SSL cert in WSA S170 7.5.1
ccie16351
I have made a mistake in the "Common name" when I generated the certificate for https proxy. On fixing the mistake at "Generate New Certificate and key", I notice, the certificate paramaters "Common name, Organization ..etc, do not get changed, even after committing the change.
I wonder if there is a way to force the change.
Sam
I haven't tried this, but you could try switching to the demo cert, committing, then switching back to a generated cert and regenerating?
Another possible option is to download the config file, edit it (its just xml), upload it, then load it as the active config.
Thanks Ken. The solution of downloading the config file, makes more sense to me. I will try it and let you know.
