Ironport WSA S170 Gateway Timeout Problem
M.Jallad
Hi Guys,
We are having problem on WSA S170 Appliance when trying to access some websites; the user receives a page indicating a gateway timeout issue. when reading the accesslogs on WSA it shows that these URLs return an HTTP 504 error code.
The Ironport deployment mode is proxy and it is protected with two firewalls; However, there is no blocking on both firewalls and we trace the connections to internet and it is passing without blocking throught the firewalls.
I was suspecting a DNS issue; so when trying to do nslookup on WSA it returns the public ip address correctly for this site.  then when trying to telnet to this public ip it returns:
telnet: connect to address 69.162.95.210: Connection refused
telnet: Unable to connect to remote host
So please share your knowledge with us if anyone knows about this issue.
5 Replies 5
Puja Mahapatra
Please refer to the article below which explains why might you see a 504 gateway timeout.
https://ironport.custhelp.com/app/answers/detail/a_id/1516
Typically in most cases the the gateway time out is due to an upstream device not responding to SYN packets sent by the WSA. For further assistance kindly open a TAC case.
Puja
Hi Puja,
i've checked the link there are no articles,
Two notes :
1. This problem happens on small number of websites other websites are normally proxied through WSA.
2. When trying to access the same problematic websites directly (without proxy) ; it opens without any issues.
I apogilize, can you kindly try this link :
http://tools.cisco.com/squish/26661
A packet capture on the WSA can confirm where the 504 is coming from. Kindly open a support case to get further assistance.
Puja
Hi Puja ,
Aha this one i followed step by step and it was confirmed that it is 504 only not 502. however , i've just done a seocnd quick look at it again and found that i skipped checking "WSA's L4 Traffic monitoring" part under
  504: The WSA is receiving a TCP reset (RST) terminating the connection with the web server.
but i checked all other troubleshooting steps regarding Firewalls, IPS's upstream devices.
So will check it again in a couple of days and will get back to you with my updates
Hi Dear,
Please have update of case. The have problems.
Victor Alvarado
