Is it possible to control Web Access on smartphone?
Andy Brennan
Hi All,
I was wondering if anyone knew it was possible to achieve the following.
We have hundreds of corporate users using an smartphones and smart-pads (iPhone, iPad). When in work they connect to a wireless network that is controlled via CWS/ScanSafe.
Is it possible to control their web access when they are connected to a private connection or cellular network?
i cannot seem to find any guides on this specific requirement. I am aware of AnyConnect for laptop users but I would like to achieve this for iPhones and iPads please. Thanks,
Hi Andy.
Yes you can control web access when connected via WiFi as you have control in the corporate network. On the cellular network I don't know there might be something out there that can control access but I am not aware.
re AnyConnect, you can download it to iPads and iPhones from the App store.But  be aware the Cisco ASA must be licensed for AnyConnect mobile devices.
Richard.
nspasov
To add to what Richard said: For mobile devices you can utilize the "always-on" functionality. For that you will need to configure the devices via an MDM of some sort.
I hope this helps!
Thank you for rating helpful posts!
