issues on WSA 6.0.1 firmware
angfeglandagan
hi,
just wonderin if anyone encountered any problems upgrading their asyncos from 5.6 to 6.0.1?
pls post if theres any
khoanguy
If you are concern, do the upgrade from the CLI in case there are standard error outputs displayed on screen which can be helpful in troubleshooting.
angfeglandagan
just recently upgraded two WSA's with version 6.0.1..
the WSA with LDAP , identities was reset to NO GROUP so i have to add the group from my LDAP
the other one was no problem....
to sum up..everything works fine..
